09-29-2018, 10:42 AM   #16
pschlute's Avatar
Well the solution on your K3 is to use the green button to stop-down meter. It is one press of the green button. Seems a better solution to a strip of foil and using the EC dial.
09-29-2018, 11:13 AM   #17
Well, that worked as well on the K30. But my nose is in the way when trying to press the green button when using the viewfinder :--) Seems I have to get the DA 50mm after all :-D
09-29-2018, 01:10 PM   #18
With all my Pentax DSLRs the result of a green button measurement in M mode will stay valid. If you take several pictures in a row with unchanged light conditions you need to press the green button only prior to the first shot.
And if the light changes a bit and you have the feel (and some experience), you can slightly modify either exposure time or aperture with the wheels. Again no green button measurement needed.
In many situations this behaviour can speed up your workflow considerably.
09-29-2018, 03:45 PM   #19
Otis Memorial Pentaxian
QuoteOriginally posted by RKKS08 Quote
What they said ^ ^ ^
While much is made of real-time exposure control, the need is overstated for most subjects. There is not much call to change the settings once an appropriate exposure is determined. Back in the old days when stop-down metering was the norm for many SLRs and even now when using a hand-held meter, the flow was/is to determine the exposure and to shoot freely with those settings until either the subject or light changed.
When I do green button exposure in M mode, I set once per subject.
09-29-2018, 06:11 PM   #20
Brooke Meyer
Guest
Why not just use manual exposure? You can adjust with the instant review and mostly the histogram . No fussing with contacts or green buttons and Bob will still be your Uncle
aperture, av, dslr, f1.7, f4, k-3, k3, k3 and legacy, k30, lens, lenses, mode, pentax dslr cameras, pentax k-3, picture
Non-K, Non-42 Adaptable Lenses jawats Pentax SLR Lens Discussion 15 05-15-2018 07:29 AM
Using manual legacy Pentax zoom KA lenses and shake reduction with K1 GaryT Pentax K-1 & K-1 II 5 09-25-2017 11:21 AM
K3 and legacy lenses rayhf1485 Pentax K-3 & K-3 II 19 05-06-2017 12:00 PM
DA-L and non * / non ltd lenses to be DC ? formercanuck Pentax SLR Lens Discussion 10 01-09-2015 06:56 PM
People Sigma 70-200mm (non DG, non macro, non HSM) Just12hvFun Post Your Photos! 7 04-17-2010 10:49 PM
All times are GMT -7. The time now is 10:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
