12-25-2018, 04:14 AM   #1
Talete's Avatar
Pixel Shift
hi everyone, how can I activate the pixel shift function? How do I shoot raw or jpg mode?
Thank u!
12-25-2018, 04:23 AM   #2
Merv-O's Avatar
On the KP, got to page 3 of the camera function and scroll down to "pixel shift resolution" and click on...there is also "motion correction" which can be enabled as well.
12-25-2018, 05:02 AM   #3
There are different ways to do it depending on the camera. It is pretty easy to change from the info screen. Just hit the info button and scroll down to where it has pixel shift on the far right then hit OK and choose the setting you want. You can also change back and forth from RAW to jpeg on that screen.
There are other ways to change as well. Personally I use pixel shift quite a bit and so I have a user mode dedicate to it with my standard settings (f11, Av mode, iso 100, pixel shift with motion correction off, RAW). It makes it really easy to pop into it without much thought.
I am assuming you have a K3 II since this is the K3 forum. I think all of that is still accessible from the info screen, but I haven't used the K3 II, so I can't guarantee it.
12-25-2018, 05:17 AM - 2 Likes   #4
Note that pixel shift is not a set it and forget it mode. Using it incorrectly can backfire and/or result on unnecessarily large raw files. Please see our K-3 II and K-1 reviews on the homepage for details.
PSR is otherwise activated via the menu or control panel. All other settings (such as file format) are controlled as usual.
I recommend sticking to JPEG mode for PSR as the camera does a great job of processing the images.
01-01-2019, 06:18 AM   #5
microlight's Avatar
The motion correction function isn't switchable in the K-3II (it's always on). I shoot RAW with PSR and develop the primary image in DCU5, as the software has the option of turning the motion correcton on/off, even if you can't do it in camera.
dslr, k-3, k3, pentax k-3, pixel, shift
Pixel shift with pixel artefacts Dericali Pentax K-1 4 07-18-2018 12:57 PM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 2 07-16-2018 02:15 PM
Workflow For HDR/Pixel Shift Photos on K-1 cesarfishman Pentax K-1 15 01-08-2017 08:40 AM
K1/Samyang 24mm Tilt/Shift and Pixel Shift DDoram Pentax K-1 3 06-25-2016 02:05 PM
Suggestion Pixel shift specific subforum Oakland Rob Site Suggestions and Help 6 05-14-2016 11:43 AM
All times are GMT -7. The time now is 05:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
