10-06-2019, 12:32 PM   #16
Seeker of Knowledge
aslyfox's Avatar
I have had this happened to me a few times
I turn off the camera, remove the lens, put lens back on and turned on camera and problems solved
10-13-2019, 06:06 PM   #17
I just had this happen to me a few times today. I was at a beach with a battery grip on and every couple of minutes, the camera would freeze and a vertical line in the middle of LCD appeared with the left half darker than the right. On the right, a set of vertical lines appeared near the right bezel. I pulled the battery and it fixed it but it kept occurring every few minutes. I finally switched the camera battery out for the battery in the grip and the problem stopped. I guess I have a bad battery?
10-14-2019, 09:18 PM   #18
Aboulafia's Avatar
I don't believe it is the same thing. My K3-II freeze. Only the buttons no longuer respond.
11-15-2019, 09:14 AM   #19
My K3 also have this problem when shooting in Live View. I have the grip on & both batteries fully charged - both are original Pentax batteries. Turn off both the camera & the grip but the Live view is still on. Remove the lens & the mirror is up. Have to remove both batteries then back to normal. If don't use Live view it won't happen. I can shoot till the grip battery went flat
body, dslr, failure, freeze, ii, k-3, k3, k3 ii, live, macro, mode, normal, pentax k-3, view
K3ii live view crash/freeze AyeYo Pentax K-3 6 01-10-2018 06:20 PM
iso and shutter speed balance to freeze humming bird wing Knock Pentax K-70 15 09-19-2017 09:37 PM
Weekly Challenge Winners of Weekly Challenge #399 " In a flash-freeze frame" charliezap Weekly Photo Challenges 5 09-19-2017 06:15 AM
Misc Freeze Frame. charliezap Post Your Photos! 9 08-08-2017 03:21 AM
Nature Freeze Motion HSS, K-3 II, HD 40mm Limited, Shanny Flash Lmcfarrin Post Your Photos! 5 08-06-2017 06:01 AM
All times are GMT -7. The time now is 06:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
