04-07-2019, 02:02 PM   #1
Issue with k3 interval shooting
On attempting to shoot star trails last night, I ran into an issue where the camera would only take 22 exposures before ending the sequence, regardless of the number I set or interval time. I was shooting 300 30 second exposures with a 2 second interval. As suggested by someone on the pentax forum, I also set the interval time inclusive of exposure time. This didn't work, and the camera still shot only 22 exposures. I tried it with long exposure noise reduction off and auto-shutdown turned off. No change.
04-07-2019, 02:40 PM   #2
Assuming default settings (where the interval is inclusive of the exposure time), with noise reduction off, you would need an interval of 32 seconds at the very least, but to allow for whatever processing might be needed, I'd increase it by a few seconds. If processing isn't complete by the time the interval ends, the next frame simply gets skipped.
With DFS noise reduction on, you'd need to double the exposure time, i.e. use an interval of 62+ seconds.
22 exposures makes sense with a 2-second interval: the camera was expecting to shoot for 300 x 2 seconds = 600 seconds, and this is essentially what happened, plus the first and last frame.
04-07-2019, 03:03 PM   #3
Aaron28's Avatar
any/all correction/reduction options should be turned off...…
reckon yer interval time was set at 32 seconds for 300 frames?
a problem I have run into recently is I must have the camera set at 1/3 ev steps and I have no issues...…
seems the timing gets thrown off or have experienced problems interval shooting when shooting set at 1/2 ev steps
04-07-2019, 03:22 PM   #4
Please note that a 30 second exposure is really a 32 second exposure (if the camera is setting the exposure length, as opposed to an external interval timer), and then you need second or two of overhead time between exposures. Try setting your interval to 34 or 35 seconds.
True Shutter Speeds compared to Nominal Shutter Speeds - Actual Measurements - PentaxForums.com
04-07-2019, 04:49 PM   #5
Ahh, I see. I did set it to 32, but wasn't aware of the processing time requirement. Does anyone know if this would create significant gaps in star trails or if shooting in continuous mode with a shutter release cable would be preferable?
camera, dslr, exposure, exposures, interval, issue, issue with k3, k-3, k3, k3 interval, pentax k-3, time
K3 ii Interval shooting with mirror lock up Rmagers Pentax K-3 5 08-17-2017 09:48 PM
interval movie on K-50 lowest interval 10sec? dvrapant Pentax K-30 & K-50 2 05-24-2016 12:13 AM
K3 Interval shooting settings boxcam78 Pentax K-3 3 05-25-2014 05:35 PM
Continuous Shooting, Exposure Bracketing, Interval Shooting etc in B Mode! kamayok3 Pentax DSLR Discussion 8 02-12-2014 01:45 PM
Why is the K3's shortest interval shooting setting 2 seconds? alasdair03 Pentax K-3 13 12-03-2013 03:25 PM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
