04-29-2019, 07:23 AM   #1
Larrymc's Avatar
I need a little K-3 Exposure Compensation Help!
I have had my K-3 since 2014 and have rarely shot in AV mode preferring instead manual mode but this past weekend I decided to try AV mode at an outdoor concert. Right away I was getting mild over exposure with the blinkies on instant review, so I dialed in 0.3 negative exposure compensation and got back to shooting but when I powered down the K-3 and later powered it back up I lost the setting. I remembered the Camera Menu memory setting and activated that setting. The only problem with that is the last EV setting is retained instead of a default -0.3 EV setting since I had added a bit of exposure compensation to get a certain "mood" in a couple of shots and then powered down again but when I powered back up there was my over exposure again. My question is, is there a way with the K-3, to set a permanent default EV compensation independent of retaining the last setting in memory?
04-29-2019, 07:43 AM   #2
Use one of the user customizable modes.
04-29-2019, 07:57 AM   #3
Larrymc's Avatar
QuoteOriginally posted by steve_k Quote
The user modes? All of mine are occupied by the settings I use when using my Pixel Radio shutter release that allow me to turn on A/F1 settings since I usually use the back button to auto focus which is the AF2 setting. I was hoping i had missed something that would enable me to setup a default EV compensation.
Thanks
04-29-2019, 09:21 AM   #4
Page 75 of the manual. Camera menu 4 Memory, you can set which settings are saved. One of them is exposure compensation.
04-29-2019, 09:43 AM   #5
normhead's Avatar
I almost always end up with a -0.7 setting on my K-3, and the setting is saved. It's always that way when I turn he camera on. I also use AV mode.
04-29-2019, 09:47 AM   #6
UncleVanya's Avatar
QuoteOriginally posted by derekkite Quote
Read again...
QuoteOriginally posted by Larrymc Quote
Memory only keeps last used, not a default value for startup.
04-29-2019, 10:40 AM   #7
Larrymc's Avatar
Read again...
Very astute UV, you win the rubber duckie!
04-29-2019, 11:22 AM   #8
Larrymc's Avatar
Yeah, when I'm in manual mode I'm usually -0.3 or -0.7 so I guess I'll use the retain memory setting and not worry too much about it in AV mode. I'll just have to be careful if I was using a different EV compensation than my normal.
04-29-2019, 12:03 PM   #9
UncleVanya's Avatar
I turned Off the memory on that function. I find it easier just to set it each time to avoid forgetting and having it set to something weird.
I'm also primarily an Av shooter.
04-29-2019, 12:40 PM   #10
Larrymc's Avatar
I'll need to think about how I want to do the compensation since I'm primarily a manual mode shooter. For my purposes it might be easier to leave the memory box checked and see how that works when in AV or the other "automatic" modes.
04-29-2019, 12:53 PM   #11
Otis Memorial Pentaxian
Of course, you noted that in the original post, right?
04-29-2019, 12:55 PM   #12
Be aware that EC applies to metering in manual mode too for both the green button and the EV scale in the finder and LCD displays.
04-29-2019, 06:13 PM   #13
Larrymc's Avatar
Yeah, I remember now, that's the reason I started shooting Manual mode in the first place. The EV compensation was biasing the EV meter in manual mode. Thanks for reminding me.
04-29-2019, 07:32 PM   #14
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
I use half-stops rather than third-stops ... very old habit based on my pre-21st century cameras when essentially you got an EV from your meter and did your own mental arithmetic when adjusting shutter versus aperture to maintain that EV. The detents on both lenses and shutter speed tended to be in half-stop increments.
In general photography I tend to punch in a half-stop more exposure to get the in-camera jpegs to look the way I want (I save both jpeg and RAW). Regardless, what this thread is telling me is there is no 'right' exposure compensation value. It is art and not science.
I almost always have to remember to change the EC when I interpret myself to be in something other than a general photographic situation. And further remember to reset my +0.5 when I am done being in a non-general photography situation. The camera remembers whatever EC I was last using.
04-30-2019, 06:51 AM   #15
Larrymc's Avatar
QuoteOriginally posted by JimJohnson Quote
I've grown used to using 1/3 EV stops and I've got my sensetivity set up in 1/3 stops also. My K-3 has been set up that way since late 2014 but I decided to give AV mode a go last Friday at an outdoor concert where I too almost 200 shots. Everything worked out fine but it was a hassle cranking in the negative exposure values every time I powered up the camera.
I've found that at 0 EV my K-3 tends to over expose by 1/3 to 2/3 stops and that tends to blow out the highlights. I use the default Bright Parameter setting and that probably accounts for the blown highlights but I prefer that parameter setting. I'll probably use AV mode a bit more but remembering to reset the EV after the power up will come with more use of AV mode. In Manual mode its second nature to get the exposure I think is correct.
av, compansation, compensation, default, default settings, dslr, ev, exposure, k-3, k-3 exposure compensation, k3, memory, mode, pentax k-3
Default Exposure Compensation for K3 julianbenjamin Pentax K-3 & K-3 II 8 12-24-2017 03:24 AM
Pentax LX Exposure Compensation Indicator Mechanism Frosty66 Film SLRs and Compact Film Cameras 8 05-29-2017 09:17 AM
Flash Compensation, Overall Compensation and Ambient Lights Rashedul Flashes, Lighting, and Studio 3 01-11-2013 04:19 PM
Long exposure / provia 200 : how to know the good exposure compensation ? aurele Film SLRs and Compact Film Cameras 3 02-18-2012 06:58 PM
Camera exposure compensation vs flash compensation raider Photographic Technique 4 09-29-2011 05:02 PM
All times are GMT -7. The time now is 05:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
