10-13-2019, 08:28 AM   #1
K3 : long duration AFC issue
Hi all, I have a problem or just a doubt, hopefully.
With my K3 I set AF.C mode with autofocus point selection set to AUTO (9 central points) . Then I set the autofocus button as the rear AF button, not the half-pressed shutter button.
Well, no matter which AF Lens I use, when I keep the AF button pressed the AF system works correctly for 10, 15 or 20 seconds, then It stops with the green 'in focus' indicator in the viewfinder blinking.
Initially I thought was a problem of the Tamron 70-200 f2.8 (not a great AF marriage with the K3) but Is not: 16-85, 35, 50 mm give the same result. So, Is there a limit on the continuous pressure of the AF button? Any of you experienced the same fact? Thanks
Danilo
10-13-2019, 09:14 AM   #2
pschlute's Avatar
Was the AF.C tracking the subject ok up to that point ? Was the subject still displaying a contrasty area for the PDAf to get hold of ?
Do you get the same problem using shutter button half press ?
10-13-2019, 09:28 AM   #3
I will test my K-3 later, but it might be a time limitation to safe battery life.
10-13-2019, 09:41 AM   #4
Yes! I focus very far some trees and 30cm some flowers, moving the camera , no issues when focusing
Yes , in the example above the subjects doesn't change
exactly, same issue
Thanks btw
---------- Post added 10-13-19 at 09:42 AM ----------
QuoteOriginally posted by othar Quote
Interesting ... let me try with a fully charged battery!
10-13-2019, 09:56 AM   #5
pschlute's Avatar
QuoteOriginally posted by mctaveck Quote
Okay.... I have no experience in using AF.C when photographing trees or flowers. The don't tend to move in my part of the world
10-13-2019, 10:00 AM   #6
I don't think a charged battery would make any difference. It might be some time limit to increase battery life from the start (like SR has to be activated with a half press every time, or LV beeing deactivated after a certain time of inactivity)
10-13-2019, 10:08 AM   #7
Crooski's Avatar
Now that you mention it My K3 showed the same behavior. After a certain time I had to press the back button again
I didn't pay any further attention to it because I use AF-C very little.
Will test tomorrow with the KP, it is now evening and too dark.
10-13-2019, 10:26 AM   #8
It seams my K-3 doesn't stop tracking no matter how long I stay on the AF-button (although I was using only the AF-point in the middle)
10-13-2019, 11:23 AM   #9
I tried my K3, in every AF metrix, spot to auto 27. It would track as long as I wanted, held the button for couple minutes (back button focus) . the focus would lock when the subject stayed still and the green focus light would be steady green, as soon as the subject started moving again the green focus light would blink and it would continue tracking.
Edit 10/14/19 Firmware is 1.30
10-13-2019, 10:06 PM   #10
So, thanks you all guys, seem 50% of us have the same issue. Although Is not a "big" issue I'd like to fix it, never say never: when your 200 years old tree will start walking one won't miss that shoot, isn't It? 😀😀
10-13-2019, 10:40 PM   #11
amodali's Avatar
QuoteOriginally posted by Roadboat24 Quote
Hi, the firmware release you're using is...?
---------- Post added 10-13-19 at 10:49 PM ----------
Firmware release? Thanks
10-14-2019, 12:39 AM   #12
QuoteOriginally posted by amodali Quote
v1.11 (and my focus confirmation light is red not green )
10-14-2019, 12:48 AM   #13
amodali's Avatar
you're missing lots of general improvements
10-14-2019, 12:51 AM   #14
Number 8 and it is green, it blinks or stay "on" for long time. The red one doesn't blink but just flash once if get focus
---------- Post added 10-14-19 at 12:52 AM ----------
Mine is 1.30.
10-14-2019, 12:54 AM   #15
If I happen to win the DA* 11-18mm f2.8 lens I will treat my K-3 with an update
af, afc k3 long pressure, autofocus, battery, button, dslr, firmware, focus, focus confirmation light, k-3, k3, k3 long duration, light, pentax k-3, release, subject
CIF in AFC mode? scc Pentax KP 6 09-30-2019 07:49 PM
AFC on the K3 madeditor Pentax K-3 & K-3 II 5 08-01-2019 01:16 PM
Flash Duration t0.1, t0.5 derekkite Flashes, Lighting, and Studio 6 09-14-2018 09:30 PM
August K-1 Giveway Thread #2 Duration monochrome Pentax Forums Giveaways 51 09-04-2018 05:20 AM
AFC and birds and the K-1 gerardbaron Pentax K-1 & K-1 II 9 03-06-2018 08:35 PM
All times are GMT -7. The time now is 04:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
