10-17-2019, 06:08 AM   #1
Sigma 70-200 f2.8 with optical stabilizer does it fit Pentax K3 II?
Hello,
guys,
If you know, does it fit Sigma 70-200 (with optical image stabilizer) 2.8 to Pentax K3 II?
I need an answer.
10-17-2019, 06:37 AM   #2
If it's K-mount, it should work : Sigma 70-200mm F2.8 EX DG OS HSM Lens Reviews - Sigma Lenses - Pentax Lens Review Database
With Sigma there is always a risk to have an incompatibility between a specific lens and a specific body, but it can be solved by a firmware update on the lens (but apparently you cannot do it yourself, Sigma can). I didn't find any report about an incompatibility between this lens and the K3-II though.
10-17-2019, 07:49 AM   #3
Sigma made lenses for Pentax as well as Canon, Nikon, Sony, etc. The different models are not interchangeable.
If you are ordering online, make sure that the seller says something like "for Pentax" or "for k-mount". If the sale makes no mention of the mount it is unlikely to fit your K-3 because only a small fraction of Sigma's sales were for Pentax.
If you already have a Sigma 70-200, compare its lens mount to another Pentax lens you own. Do the mounts look very similar with notches and tabs in the same places?
10-17-2019, 08:51 AM   #4
i have and use it on my K3
10-17-2019, 08:56 AM   #5
ChristianRock's Avatar
It will fit only if it's a K-Mount Sigma. Sigma released versions of this lens with different mounts for every major DSLR system.
10-17-2019, 08:59 AM   #6
QuoteOriginally posted by zangura Quote
Hello,
guys,
I need an answer.
If it is a K mount it will fit. While there are some Sigma lenses that provide optical stabilising in K mount I am not sure the 70-200 mm is one of those (if it is make sure to either use SR or the lens stabiliser, not both at the same time).
I think some Sigma lenses will leave a scratch on the K-1 body, but with the K-3 you should be on the safe side
10-20-2019, 08:31 AM   #7
I have a Sigma 70-200mm f2.8 APO DG HSM attached to a K3. As others have said, it's stating the bleeding obvious that the lens needs the Pentax K-mount.
One observation, when walking around with this lens, it is not unknown for it to bounce/rub against one's body. That in turn can accidentally switch on the in-lens stabilisation (as well as the manual/auto option). A nuisance if you use in-body stabilisation.
10-20-2019, 08:46 AM   #8
Seeker of Knowledge
aslyfox's Avatar
Hello,
guys,
I need an answer.
is this the lens in question
The lenses we will be examining are shown above. It's important to note their exact names, as both Sigma and Tamron have produced multiple variants of their 70-200mm lens, and the ones we're looking at are the latest models. From left to right: SMC Pentax-FA* 80-200mm F2.8 ED [IF], Sigma 70-200mm F2.8 APO EX DG OS HSM, Tamron 70-200mm F2.8 Di LD (IF) Macro.
Read more at: Fast Sports Zoom Lenses for Pentax Review - 70-200mm Sigma & Tamron | PentaxForums.com Reviews
if looking at a 70-200 F2.8 don't forget the Pentax
HD Pentax-D FA* 70-200mm F2.8 ED DC AW
Introduction
In order to cater to professional photographers, a manufacturer must meet several requirements. In addition to a full frame body, a 70-200mm F2.8 telephoto lens is very high on the list. It is thus not very surprising that Pentax released its own version of that lens just prior to the launch of the Pentax K-1 itself.
Read more at: https://www.pentaxforums.com/reviews/hd-pentax-d-fa-star-70-200mm-f28/introd...#ixzz62uTwYt8D
dslr, k-3, k3, pentax, pentax k-3, pentax k3, sigma, sigma 70-200 f2.8
AF improvement K3 & 50-135* vs K3 & 70-200* vs K1 & 70-200* for basketball? RedBoomer Pentax SLR Lens Discussion 13 07-25-2017 12:06 PM
$249.99 - Sigma 18-250 F3.5-6.3 DC Macro OS HSM with Optical Stabilizer glee46 Pentax Price Watch 4 08-09-2015 02:26 AM
Tamron 70-200 F2.8 vs Sigma 70-200 F2.8 EX DG HSM II - Battle of the older telephotos JinDesu Pentax Lens Articles 45 11-03-2014 06:30 AM
built-in optical image stabilizer on the coming 70-200ish Zoom / * Tele Zoom lens? grahame Pentax SLR Lens Discussion 40 09-21-2014 08:30 AM
Sigma 70-200 HSM II vs. 70-200 HSM II OS Mehlsack Pentax SLR Lens Discussion 4 02-19-2011 10:05 AM
All times are GMT -7. The time now is 05:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
