You are doing something unthinkable to most of us Pentaxian, I even not dare enough to replace the backup battery ! I broke some tiny and fragile flat cables while fixing tablet and notebook keyboard. Although I'm from electronics background my tools and eyes are not good enough for handling tiny components and parts, how old is your camera ? mine is 8yrs+ old. Btw if you can fix that circuit board I'm sure fixing the SDM motor is piece of cake to you ha ! good luck fixing !
---------- Post added 01-04-23 at 01:17 PM ----------
Originally posted by RKP Chennai Hi Pentaxians,
This is my first post, so please guide me if I am posting this in the wrong thread.
Few months ago, I bought a used K3 with no power issue. I thought I can try to solve the issue by opening the camera and find the faulty component within the DC to DC converter and try my luck to change it hoping that it will work with a midas touch ):-. I have found some components short to ground (GND). I have attached pictures depicting the suspected fault with yellow and red colour and green for good. I tried to isolate capacitor and diode which were initially showing short to GND but up on testing it with one side disconnected from circuit it showed normal findings. I have also looked at the PMIC chip (2 nos in K3, 1 is good and the other looks faulty). I have attached the schematic for BD9865WMV. The red oval ring showing 2 wires are showing short to GND. The wires shows + and -. I need advice from you guys regarding how to strategically find the component(s) which are faulty.
Regards,
RKP Chennai
Btw do you know which pin of the GB-5 grip responsible for AA battery power ? mine failed to work suddenly even with Lithium cell, so that I want to try AA but didn't work either, and I found a 'sunk pin' contact at the grip I believe is for the AA, it's more easy to fix so I'll start there, thanks !
