01-31-2020, 07:24 AM   #1
K3 shutter release button problem
Hi,
I use K-3 for about 3 years (I upgraded from K-30 after some aperture solenoid and shutter problems) and now I started to having problem with shutter release button. When I do half-press to focus it always start focusing but when I do full press to take a shot then sometimes nothing happen (focus locked OK) like the 2nd contact in the button didn't switch on full press. As a workaroud it works when I press the button by finger not in the middle but close to back edge (side to me) then It always take a shot on full press.
It's not a serious problem but I'm a bit disappointed that Pentax used some crappy switch in top model camera (I expected it should be built more robust than K-30). Does someone else have this problem on K-3? My cam is now out of warranty. Does anybody know if the switch is the same (or have compatible dimensions and contacts) as in K-30 so I could replace it?
01-31-2020, 07:45 AM   #2
Fries's Avatar
It could just be stuck a little bit because of dirt. Shooting near seawater can also introduce salt and have the same effect. That happened to my K-3 and a professional Sony video camera. If that is the case it has nothing to do with the build quality of the camera.
01-31-2020, 09:15 AM   #3
Hm, maybe but K-3 body should be well sealed and I didn't take it near to sea. How did you solved it? Just did some cleaning? Of course I should try it first but I have bad experiences with other mechanical switches that simply wear out and the contact resistance will rise that more pressure have to be applied until it loose contact at all. On other hand I have no any problems with shutter release button on all my prev. cams including cheap compacts...
01-31-2020, 10:47 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by RayeR Quote
No problems here in almost five years of ownership. Is there any chance the switch has been gummied up with errant juice or soda?
01-31-2020, 11:30 AM   #5
No no, I take care about that. In a case of corrosion I would expect that it will not be sensitive on direction how button is pushed but it would have a constant problem.
I found one video where AF button is replaced -
on 1:51 I can see the shutter release button but not in a close detail. I have to browse my photos of disassembled K-30 and compare if the switch could be the same...
01-31-2020, 01:13 PM   #6
Wingincamera's Avatar
I've never had a problem with switches on any camera, so what I am about to suggest might or might not be a good idea. My Honda Goldwing has push type buttons for the radio, CB and other functions which are all out in the weather. One of the buttons became stuck and I suspected a piece of dirt or grit got lodged into the button. I used a "can of compressed air" to blow into the button and it cleared out the switch and it worked properly again.
Maybe some lint or dust is lodged around your shutter switch and prevents it from working properly.
01-31-2020, 03:26 PM   #7
Fries's Avatar
The compressed air option mentioned above seems like a good one. I can not in good conscience recommend the solution I used which I detailed in this thread: Pentax K-3 autofocus stuck - PentaxForums.com. It did work though...
02-16-2020, 08:04 PM - 1 Like   #8
Compressed air - no way...
I had to follow the Belarussian guy disassemble video to remove top cover. The switch itself is well covered so nothing can be done without getting in. I had to disassemble the tiny switch and observed that the metal membrane was a bit oxidized on inner side. It looks like a silver (a bit cheaper), definitely not gold that should stay innert. So I cleaned the membrane surface and contacts in the switch body and put it back together. Now my shutter-release actuate sensitive and accurate as before the problem started so I hape it will last long. There seems not be any replacement switch on ebay/aliexpress... If someone else will have this problem I warn that the switch and it's internals are very tiny, sharp vision, tiny tweezers and still hands needed...
07-08-2020, 10:40 AM   #9
vector's Avatar
Just followed the disassembly video and cleaned up the switch membrane as you posted here and my K3 seems to be back to normal. I have been having the same issue with the shutter switch for a while but recently it had been getting worse. Now it fires without hesitation. Thanks for posting this.
button, dslr, focus, k-3, k-30, k3, k3 shutter release, pentax k-3, press, release, shutter, shutter release button, switch
Pentax MX, plastic insert in shutter release button hoshisato Pentax Film SLR Discussion 3 07-25-2019 09:40 PM
Pentax 67II shutter release button problem vldmr1 Pentax Medium Format 7 02-26-2019 09:51 AM
Shutter release button off (Live View Only). Hidrieus Troubleshooting and Beginner Help 9 06-16-2018 12:57 AM
Disabling Shutter Release Button's Half-Press Focus bats Pentax K-3 35 02-14-2015 09:30 AM
problem with spotmatic sp shutter release button cvsuave Pentax Film SLR Discussion 3 04-21-2009 04:41 AM
All times are GMT -7. The time now is 10:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
