02-07-2020, 01:22 PM - 3 Likes   #1
Canada_Rockies's Avatar
Burning Mountain
A mountain close to Sparwood has been burning underground for over 30 years in coal seams that resulted in no less than 3 mine digs closing in the same mountain. The latest, panel 6, is closest to the surface and when conditions are right, we see steam generated from the hot granite figures above the panel.
These photos were taken on the morning of 7 February 2020 and are the first where I was able to capture the steam against an open sky, thanks to my friend Rick who saw them this morning on his way to work and texted me.
One was taken at 300mm, the other at 55mm to show how close the mountain is to the District of Sparwood by including the roof of our local Glass Shop.
Burning Mountain steam 300 mm
Burning Mountain 55mm
02-07-2020, 02:53 PM   #2
bertwert's Avatar
Fascinating that this happens. Was it originally human caused? Thanks for sharing this.
02-07-2020, 03:25 PM   #3
There were coal mine fires that burned for years where i live here in western Maryland and this is something we used to see all the time, most if not all the fires have died out after they cut off the air supply to the fires.
02-07-2020, 03:26 PM   #4
We have one of those here in the States too, burning for decades. Nothing you can do about it.
02-07-2020, 04:18 PM   #5
QuoteOriginally posted by bertwert Quote
Only in the sense that humans dug into the coal seam and worked underground. Combine methane and coal dust and it takes almost nothing to set it off, sometimes explosively.
QuoteOriginally posted by bschriver11 Quote
It isn't possible to put these out. Granite mountains are not air proof. All three of the same were flooded, but the water table is much lower than the seam.
QuoteOriginally posted by Apet-Sure Quote
Only the UK can put them out, and then only those below the oceans. They blast to let the water in.
02-07-2020, 04:45 PM - 1 Like   #6
luftfluss's Avatar
Centralia, PA?
02-07-2020, 04:46 PM   #7
luftfluss's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Good thing you had your camera with you!
02-07-2020, 04:47 PM   #8
Starved of air they will go out. The mountains in western Maryland are not granite.
02-07-2020, 05:10 PM   #9
I sit corrected.
02-08-2020, 07:51 AM - 1 Like   #10
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Yeah, a lot more than one. Check out Teddy Roosevelt National Park in North Dakota. The region burned for thousands of years. There were coal vein fires when we passed though a couple decades ago. As mentioned, coal and methane is a wicked combination. Add a little oxygen and a tiny bit of heat and you reach flame point. Lightning does most of the ignition, but so can spontaneous combustion from inside a decaying pile of plant material.
55mm, dslr, k-3, k3, morning, mountain, panel, pentax k-3, steam
Cityscape Burning heavens MrKodak Post Your Photos! 9 08-30-2018 07:55 PM
Abstract Fireworks at the Elbe (the elbe is burning) DrumBox Post Your Photos! 5 08-20-2018 12:12 PM
Night burning the midnight oil françois Post Your Photos! 4 08-11-2018 03:59 AM
Landscape Have you ever seen burning water? - Dutch Mountain! Rense Post Your Photos! 7 12-24-2010 07:43 AM
Burning Mountain falconeye Photo Critique 8 02-08-2008 06:06 PM
All times are GMT -7. The time now is 06:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
