Originally posted by Robert N I note the original image resolution, when viewing with Photoshop Elements, is 240 pixels per inch
In addition to the excellent answer above I would add the following:
If you view an image on any electronic device the pixels per inch (ppi) number is mostly irrelevant. Your K3 will produce an image at 6000x4000 pixels. If you view that on a screen the graphics software of your computer or tablet will take care of displaying it correctly depending on your screen resolution.
When you wish to print an image the ppi number is relevant. but it is a number that can be changed at will. So for example, if you want to print at a size 12" x 8", and the print lab says it wants images at 300 ppi you can do the maths....... 12x300 = 3600 8x300 = 2400. So you need to downsize your image from 6000x4000 pixels to 3600x2400 pixels.
The print size; ppi number; and pixel resolution of your image are three sides of the same equation.... print size x ppi equals the resolution.
