Hello!
I would like to ask if some of you tested the IBIS performance on both standard focal length lens and telephoto. I would like to buy a good 70-200 mm zoom, and my only options are Tamron, and Sigma (both f/2.8), but since Tamron doesn't have IS, I'm curious if the IBIS will be effective on this range.
I only tested it with 50 mm lens and results were somewhere between 3.0 - 3.5 EV. I compared it to Sigma 17-50 f/2.8 OS (yep, I have the "before the OS purge" version) and on 50 mm Sigma's OS was like 1/3 EV better, but in 17 mm the IBIS was better (didn't take precise test, just noticed it in the field).
If somebody has a lens with a 200 mm focal length, please share your results. Thank you in advance!
