Originally posted by AstroDave Nice Andromeda shot. Were you binning the pixels (3 by 3) in the composite? The Astrometry.net scale reported with your image is 8.750 arcsec/pixel . I have measured the scale of my K-3 and DA* 300 mm (also with Astrometry.net - here's a blurb I wrote about its use a while back:
Easy Determinations of Camera Scale Factors (arcseconds per pixel) - PentaxForums.com ) and get a scale factor of 2.765 arcsec/pixel - about a third of your value.
The pixel scale is result of a 50% downsizing and then a crop. I downsized because I was using a 32-bit version of rnc-color-stretch to do stretching and it couldn't handle the full 24 MPixel frame. I didn't really need to downsize that far (to 6 MPixel) but that also made rnc-color-stretch run faster. I now use the 64-bit version of the program (actually, of Davinci, which rnc-color-stretch requires) and don't need to downsize. The additional crop was probably to get rid of edge artifacts from stacking but also for aesthetically pleasing framing.
Quote: By the way, while I do the full mirror up/2 second delay routine when astro-shooting, I think the concern here about blurring is a bit overblown. The time for the camera to settle is a fraction of a second, which is quite short compared to, say, a 20-second or more exposure. You won't see much of an effect on the image. Equally useful is to hold a black piece of paper in front of the lens as the exposure starts and then moving it out of the way as soon as the shutter opens.
Like you, I am just being safe. I have actually triggered the shutter using my finger when using a 200mm lens and seen no effect in the image. But the mirror-up delay costs me only two extra seconds per shot, so why not? As for the black paper trick (ages ago they used to talk about using a black hat), shooting a hundred or more subs with Astrotracer is enough work already!
Shooting the moon through a 762mm telescope, on the other hand, definitely needs mirror-up delay. It could also really use an electronic first-curtain shutter but the K-3II doesn't have that and never will. (I think we saw what will be the camera's last firmware update some time ago.) However, I have been
successful with Pixel Shift Resolution a few times.
