Originally posted by pschlute Do you have any other "K" or M series lenses to try?
I would suggest that if your only problem is a consistent 1.5 stop overexposure with manual lenses then that is easy to live with. Just use the histogram to confirm.
I use the histogram to review exposure with modern lenses too. It is the best tool in your camera by a long mile.
I had to pry a M-50 1.7 lens out of my daughter's hands to experiment with. The issue is barely noticeable with the 50mm focal length lens. With a 135mm and 200mm, K-3 meters accurately with either OPV or LV (same exact settings selected by camera). It seems that only shorter focal lengths 20 and 24 ( on the A ad K series lenses) gave my K-3 OVF metering challenges. With the DA 16-50, set at 20 or 24 mm, the K-3 metered just fine. Easy enough to adapt to, I guess.
