Originally posted by Mooncatt
Manual and bulb modes only allow standard and red eye reduction on the camera (confirmed in the manual as well).
We must be using different manuals. I have the K-3II manual open in front of me. Do you have a page number for me?
Is that what the setting circled in my pic is? When I got the kit, the flash didn't come with instructions, and my last kit worked the way I expected. I could use rear curtain sync on any non-auto mode, and there was nothing to set on the flash other than the power level. So this seems like a step backwards to me.
Yes, that is the setting. If you need a manual for the flash, it can be downloaded at:
Operation Manuals Download : Support & Service | RICOH IMAGING
I have the AF201FG manual open in front of me as well. The manuals come in handy when helping people troubleshoot.
As for seeming like a step backwards to you. I am assuming that your previous kit had a compact proprietary flash that could not be used on other than that brand camera. With that type of system, the flash logic is built into the camera with the flash itself usually having only an on/off switch. That is very handy and uncomplicated, but fairly limiting.
Your K-3II is positioned somewhat differently in that the settings on the camera are concerned with behavior related to exposure balancing. The flash on the other hand takes care of the flash stuff. Trailing curtain sync requires that the flash fire at mark T - d, where T is the arrival time of the trailing curtain and d is the flash duration as determined by the flash exposure automation. You could fire when the trailing curtain starts, but that would be way too early for a short flash duration and would result in a leading ghost image. The flash asks the camera for T and fires right on the mark, having calculated d in advance.
Having read the above, yes, you can do trailing curtain sync in all exposure modes other than green and X. Just tell the flash you want trailing curtain sync and take care that the shutter speed is 1/90s or less (K-3II manual page 91). There is a ton more that your current kit can in regards to flash that you might find interesting. The AF201FG is extremely basic, but when you are ready to spread your wings, there is a lot of cool stuff out there.
