Originally posted by Mistlefoot So I wander around and dust, etc, falls in the top but lands on the centre plate. I then swap lenses and when the unit reverses all that crap lands on the mount end of the lens???? You would need to cap it regardless. A centre plate would not keep anything clean...
Good point, I suppose you're right. A swapped out lens normally needs to be capped anyway, so maybe that shouldn't be considered a big time waster - easier to just put the cap on the Lens Flipper than have to go through the whole process of swapping lenses in and out of a carrier.
Still, I can't help thinking there must be a better way than to require the lens cap ... Nevertheless, camera stores love to leave used lenses standing in their cases uncapped for months on end, so how bad can a little dust be? Just as long as it's protected from pebbles, sand blasts, ocean spray, and the like, I don't think a little dust falling in there will hurt, and anything bigger can be shaken out in one second before putting the other lens on.
