Originally posted by goubejp Anything above F11 is not useful cause of diffraction anyway
Yes and no. That depends on the lens. f11 on a 50mm lens, as you know, is a lot different than f11 on a 300mm lens. On the 50mm lens, f11 is an aperture opening of 4.54mm. On the 300mm lens, f11 is an aperture opening of 27.27mm. Diffraction is a result of aperture size, so the longer the lens the greater the required f stop before diffraction is an issue. That's one of the reasons why large format photographers can use smaller apertures without image quality loss.
On a 2,000mm lens, the aperture at f13.5 is 148mm across. Even at f32, the aperture is 62.5mm across -- many Pentax lenses could fit through that aperture opening.
