Originally posted by stevebrot Ummmmm...No, not a lens characteristic.
If you tell me that field of view and depth of filed i.e. for telephoto lens is not a lens characteristic, than I will be gladly taking back all I mention before
This is practical example and I hope that everyone will understand... You can use practically any lens for portraits, it doesn't matter the focal length, but every single focal length has unique characteristics. Take an DA35mm lens and take picture of the subject/person at let say f5.6. Than take an DA70mm or/and DA200mm lens and take the picture of the same subject and make sure that the framing of the subject is the same (Height, length, width, position, etc.).
You will get 3 pictures with the subject at the same place and position in every picture. Is something different there?
Yes, it is... Notice how background changed?
People tend to say that it is compressed, but lens did not physically compress anything or did the lens has some magical power that I did not notice? Simple, field of view changed and the impression given is the compression. Did something else changed there?
Yes you bet it did... The background is more blurred from lens to lens, even you took the shoot at the same f-stop, say 5.6
Why? Simple depth of field changed while longer focal length lens magnifies everything in the frame and since the subject is closer to you than background and both of them are magnified that may give you appearance of more shallow depth of field than it is and this is creating bokeh, that might be distracting or pleasant and you have to pay attention where magnified will appear in the frame.
I do not want go any more into details in regards of field of view and depth of field, otherwise it will be simpler to write a book and publish it.
Depth of field and field of view are unique characteristics of every lens including
distortion (click to get explained this) which is also
characteristic of the individual focal length of the lens...
Hope this is helpfully and explains more. No offence taken and hopefully none given!
