Originally posted by Lowell Goudge What he is talking, although commonly referred to as perspective distortion, is actually nothing to do with "perspective" at all. what the distortion is all about is magnification ratio.
consider, that lens magnification, in simple terms is the following
Magnification = Image size / Subject size = focal length / distance
This was a very helpful post! You correctly guessed that I like numbers, so I found this explanation very intuitive to my brain's wiring.
Originally posted by Tanzer Wide angle lenses can be used to make women's legs look longer when shot from close to the ground, and men's shoulders look broader when shot from slightly above. So the perspective thing is very real, but whether it is a problem or not depends on who your subject is, and what (face, head/shoulders, 3/4 body, or full body) you are shooting.
Right. I've used perspective distortion to effect a couple times. I find that you need a really wide angle lens and focus very closely. I do plan to use some of it with the subjects I will be shooting. The legs thing may come into play as well, but I definitely will use perspective distortion with some of the props the cosplayers use.
Originally posted by BrianR Nothing I've shot has ever looked like thise short focal length shots in the link, fortunately.
Originally posted by calsan It's the same with a building, if you stand right in front of the door, you only see the door, but with a wide angle lens you can stand on the door mat and fit in much of the building, but the building will look more natural photographed from across the street with a longer focal length. Buildings don't complain about their doors looking too big, however.
I've noticed that architecture is incredibly unforgiving when it comes to focal length and angle of shot. It doesn't take much to get an utterly hideous shot.
Originally posted by Tanzer Actually if you take the picture from the same distance using all three lenses at f/5.6, the DOF will be identical. Of course, you will then have to crop the 35mm and 70mm images considerably to get a similar subject framing as the 200mm, but once you do that, you will get the same background blur. <-- Edit: I think I might have overstated this.
Originally posted by stevebrot Below are two photos taken from the same position using identical camera settings. The only differences are the focal lengths (35mm and 55mm) and the fact that one was cropped to the same field of view as the other.
It is fairly obvious that the perspective is identical between the two. It is also obvious that the DOF is quite different despite both being shot at f/11.Edit: Actually, the lens should not really make a difference.
The lens does make something of a difference. There's a big difference in the Sigma 18-35 and FA31. It's not just quality of bokeh, either. The FA31 just obliterates backgrounds while the Sigma blurs them.
The focal length, of course, makes a huge difference. At the short end of the Sigma, even if you focus close at 1.8, the bokeh is not that strong. It becomes much stronger as you reach the long end of its range.
