Originally posted by MadMathMind I was talking with another photographer and he said that he really dislikes shooting portraits below 85mm because "you get a distortion where it makes things closer to the camera look bigger, and things farther away look smaller." This is the first time I've ever heard that explanation.
He shoots full frame (Canon), so the equivalent on APS-C would be ~56mm. I've shot a lot below that and never noticed unacceptable distortion. I know 85mm (FF) is the sweet spot for portrait lenses, but is this why? The Pentax 50mm lenses are simply gorgeous for distortion-free photography. Could it be a Canon thing? I saw their 16-35's results and I was not impressed at all with the ridiculous distortion.
What he is talking, although commonly referred to as perspective distortion, is actually nothing to do with "perspective" at all. what the distortion is all about is magnification ratio.
consider, that lens magnification, in simple terms is the following
Magnification = Image size / Subject size = focal length / distance
OK for all the purists there is a secondary term which becomes important if you are closer than 10* the focal length, but we will forget that term for now because you are always shooting beyond that range unless you are really. really close.
What you can see, is that magnification is inversely proportional to distance. So anything that is closer to the lens gets magnified more, things further away get magnified less. Of course, when you are far away, the impact is much less because the change in distance has little impact on overall magnification between different parts of a subject.
now lets consider taking a portrait, lets , for fun, say it is head and shoulders shot. so the subject is likely 30cm high.
you shoot with an 85mm lens, and you fill a vertical full frame, 36mm
to do this requires magnification = 3.6/30 = .12 and your working distance is 708 mm.
now, lets consider your subjects nose, which the tip of could be 25 mm (really big nose?) closer or 683 mm from the lens. its magnification is .124 or not quite 4% larger in proportion to the rest of the face. OK not so bad, 4% is really not that much.
Now, lets consider the same shot, but with a 35 mm lens, but retaining the same fill on the frame.
to get the same framing i.e. magnification on the sensor, you now move to 269mm from the subject. but their nose is now 244mm away, and the resulting magnification on the nose is .143 or almost 20% larger in proportion than the rest of the face.
this is what the discussion is all about. The shorter the focal length, the nearer you need to be to a subject, and the higher the apparent distortion due to the difference in magnification of the near and far features.
Shorter and longer lenses don't have different perspectives when shot from the same distance either, an 85 mm shot is just a crop out of a 35mm shot from the same distance. it is moving closer that gives "perspective distortion" because now you change the magnification ratio of the relative parts of the frame.
This same principle is what leads to barrel distortion and the bending of straight lines in fisheye lenses. as you move to the edges of the frame, the subject is further away from the lens, so the subject is magnified less.
Now lets apply barrel distortion correction to a wide angle lens, to correct for barrel distortion really means that things futher off center get magnified more so that you get straight lines of rectangular objects, now put parts of a subject, with a wide angle lens (again the nose is a good example) toward the edge of the frame, and it gets magnified even more than the central part of the subject, so the 25mm nose again gets really big in a hurry. For portraits with wide angle, you might actually want some barrel distortion to get more flattering shots.
