Originally posted by Nicolas06
You do what you want man. A well done workflow will almost completely hide any difference from a workflow point of view independantly of the file format you choose to use, be it raw or jpeg.
The main argument for JPEG is being able to share instantly (for example to family) while raw you'll need to export... Likely you'll do the same if you do some cropping/straightening anyway.
There could be the size argument but with a modern computer that should be quite ok now. 2TB is like 90$ and it's already 65 000 raws from K3. That should quite a few years already if you keep only the shoots worth keeping.
The main argument for raw will be the post processing will simply give better results. Sometime this is more theoric (cropping, horizon...) and not very relevant. Sometime this quite visible (pushing shadows, noise reduction, white balance, correcting exposure, getting back burned highlights).
What can I say? My father was against raw until he was using photoshop element. He used the full argumentation for JPEG and against RAW. Simply because element made RAW processing a hassle. Now that he asked we offer him lightroom, there no more difference in workflow between RAWs and JPEG, he started to use Raws just as test in a few more case and changed completely his mind on the usefullness of it. Now he start to use Raws more and more.
Maybe other would find no interrest for it, even after many tries.
I think you misuderstood the intent of the comment.
I do not disagree with respect to the need for sometimes, minor edits, etc. and maybe, for example, i am using the wrong photo editor, and would find raw more interesting with another program, who knows. all i intended to show was that the possible need for framing work in PP is often used as the justification for raw. "You are going to be doing PP anyway so why not use RAW" is the argument you often hear, but the need to crop and straighten is simply not enough on its own, for me to justify RAW. that is all i intended
I am not Anti RAW, i see it as a tool, as are many other things you can do, and it is something people need to decide for themselves,. As you say "Do what you want" .
