Originally posted by Digitalis Does that mean you will be running a white balance deficit?
Depending on what you set for WB yes.
I generally return mine to daylight, because it is easiest to correct either from red or green back to daylight if you need to when you forget to think about your real conditions
Normally though the only issue is when you do side by side comparison of images made on different days, but you may wish to think about it a little, in the preparation of your shot. Your camera has overcast, daylight and shade WB settings for a reason,
