Originally posted by bdery Carl, if you shot in RAW, you can probably bring out much more from that image. It's still pretty good as it is.
Yes this was shot RAW. It's actually a merge of two shots. The first one for the sky for 80 sec., F2.8, ISO 800 using O-GPS-1 and the second one for the forgeround at 20 sec., F4, ISO 800, with refocusing between the shots.
I'm not sure this could be improved much more in PP since the sky is already heavily pushed in PP. The background light from the moon is practically at the level as the light from the milky way (they're both on the same spot on the curves). It's very difficult to boost the milky way without also increasing the background, or decreasing the background without making the milky way dissapears... Or, at least, making these adjustments look natural.
