Originally posted by UncleVanya Or better yet - RICOH announces new DIGITAL FILM! Fits into any existing 35mm camera and transforms it to a fully working digital FF camera. By removing the film pressure plate to add room and by using NFC/Wifi to send the output to a cell phone RICOH has made the impossible possible!
I would buy that in a heartbeat. I would even accept (hell,
prefer) a non-wifi version and having to take the micro SD card out manually and plug it into something to see the pics. This would keep things simple, and while it would be a backward step from the ability to preview instantly, it would still be more convenient than film. There are things available to allow smartphones to read a microSD without having to peel the back off, so you wouldn't even need a laptop with you - though you might want a tablet, to have a larger screen to view and edit things on.
One would have to find a way to set the DX coding for cameras that didn't have manual override (P3, P30, etc), but if the digital film cartridge abuts the DX sensor there's no reason why it couldn't ground or charge the appropriate pins, either with a hardware slider on the digi-film cartridge or by setting it in software when you plug the SD card in to offload the previous set of images. Tethering could wait until miniaturisation improved. Certainly, by not having to power a screen or the mirror, your power requirements ought to drop markedly, and a stack of LR44s or a small rechargeable might just be enough.
And unlike the small kickstarters, RICOH have the engineering and manufacturing capability to do this and make it work. If the independent entrepreneurs can come as close as they have in the past, RICOH should bolt it in without problems.
