Originally posted by Danaher Dempsey Assuming the use of fabulous lenses, where is line at which the high resolution quality will be of value or not?
You need to define your needs, like MP, digital noise (more MP more noise, many still prefer the 16MP sensor over the newer 20 and 24MP in this regard), budget (you can get slightly older technology with less MP for a really low price these days), and storage space (more MP means bigger files, need more space, better CPU to process and view). If you only resize photos to send them by email, post them to facebook, and so on, then like you said, K10D is good enough; better to spend the rest of the budget on other things. If you want to make large prints (bigger than A4), if you want to take photos and do a lot of cropping (to increase apparent magnification), then it might be worthwhile to get higher MP. You can notice the difference between low and high resolution photos on any screen by simply zooming in/magnifying the photo. You can try this right now - just go find a full size photo taken with K-3 and download it alongside a full size photo taken with K10D. With a high resolution 5k screen, I think these differences would be more apparent than usually (as long as you don't resize the photos), bu the actual differences will be no different in absolute terms. Its a thing of compromises and appearances.
As Adam said, the more the better. Great lenses will appear even better on higher resolution cameras. Do we all need it? No. Will it be noticeable? In some conditions, if you know what to look for. Should you buy the latest technology? Yes. Should lenses have priority over cameras? Yes (buying a lens is better investment, can be used for years, decades, on various cameras; digital camera only loses value over time). Is other gear, like tripod, flash, critical for obtaining a truly great photo? Fairly often.
