Originally posted by othar Use a umbrella or your hand to cover the lens from the worst, waterdroplets on the front element won't improve IQ anyway. Keep the camera covered between shots.
Exactly! There's a lot that can be done even if your camera and lens aren't water-resistant. Shoot under an umbrella...use a plastic bag to cover the camera until the rain lets up...step under some cover to lessen the amount of rain falling on your gear. In short, just use common sense. Even non-weather resistant gear will tolerate mists and high humidity fairly well. Just keep in mind that digital cameras are electronic products and use them the way you'd use your cellphone, maybe. Avoid getting them soaked and you'll probably be okay.
