01-11-2016, 06:10 AM   #1
Digitiser of Film
BigMackCam's Avatar
What's the point of variable aperture in small-sensor cameras?
Alongside my main DSLR gear, I have a couple of compact cameras - a Fujifilm XF-1 with 6.4-25.6mm f/1.8-4.9 lens, and a Panasonic TZ70 (ZS50) with 4.3-129mm f/3.3-6.4 lens. The sensor crop factor on the Fuji is ~3.9x, while the crop on the Panny is ~5.6x.
In terms of blur control and depth of field, the XF-1 broadly gives equivalent results to a 25-100mm f/7-19 lens on full frame, while the Panny acts more like a 24-720mm f/18-f/39 lens.
My question is this... assuming that there isn't so much light that exposure can't be controlled via shutter speed and ISO sensitivity alone, is there any real benefit to stopping down the lenses on cameras like these, rather than just shooting them wide open all of the time? It seems to me that with the Fuji, there may be rare circumstances where a little extra depth of field might be useful, but we're getting close to the point where diffraction will become an issue... and as far as the Panny goes, diffraction must already have kicked in even wide open (where in full frame terms it is already very narrow), so stopping down further will only increase that. The only real benefit I can see to stopping down would be to allow longer shutter speeds, in order to get motion blur - yes?
01-11-2016, 06:34 AM - 1 Like   #2
AFAIK the DOF may BEHAVE like a lens of extreme f stop, but the diffraction effect does not kick in until the physical lens has actually closed down far enough.
01-11-2016, 06:41 AM   #3
paulcote's Avatar
would seem to get these small sensor cameras to use low iso you would need to shoot wide open. I just recently got into flash photography and it seems you can adjust your aperture or your flash. So, sometimes the flash can be just overpowering and maybe then you'd wnt to stop it down? I have a long ways to go to get how to use the flash but it seems like a good addition. Maybe you'd need to stop down to shoot into the sun as well.
01-11-2016, 07:04 AM   #4
RuiC's Avatar
The variable aperture on these lenses has nothing to do with exposure choices but rather with ease of lens design only!
01-11-2016, 07:06 AM   #5
Edgar_in_Indy's Avatar
Isn't this kind of like asking why do they only put small engines in econocars?
01-11-2016, 07:10 AM   #6
UncleVanya's Avatar
QuoteOriginally posted by pathdoc Quote
Diffraction in a smaller sensor comes earlier. I don't know if the equivalence of f stops has any relationship that is predictable to tell you about diffraction but you get diffraction on these sensors pretty early.
---------- Post added 01-11-16 at 09:11 AM ----------
QuoteOriginally posted by Edgar_in_Indy Quote
I think the question is more. Why shoot these at anything other than wide open.
01-11-2016, 07:16 AM   #7
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
I think that's correct, but the actual aperture for, say, a 5 mm focal length at f/2 is already 5/2 = 2.5mm, whereas the same f/2 on a fullframe camera with a 24mm focal length is 24/2 = 12mm. Because of the crop factor, however, both setups could provide the same angle of view.
Also, if you look at the Photozone reviews of Q lenses, Klaus finds that a lot of lenses run into diffraction very early on because of this.
01-11-2016, 07:21 AM   #8
Aha. I stand corrected.
01-11-2016, 07:24 AM   #9
Digitiser of Film
BigMackCam's Avatar
Exactly
01-11-2016, 10:50 AM   #10
luftfluss's Avatar
If I'm shooting close-focus or macro on a P&S, I find it necessary to decrease aperture in order to get sufficient DOF.
And if you have a fast lens - like the 01 Prime for the Q system - the edges will sharpen up at f/2.8. For a photo where I am not looking for any kind of shallow depth of field - like a landscape - I'm willing to sacrifice a smidgen of center sharpness for sharper borders and even sharpness across the frame.
01-11-2016, 11:02 AM   #11
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by luftfluss Quote
Aha... yes, the close-focus / macro situation makes sense. I hadn't thought of that. If you're close focusing but want to keep a good level of detail over the entire depth of the subject, or further back still, it would make sense to stop down.
Thanks!
01-11-2016, 12:10 PM   #12
If they are like most zooms they probably perform better in terms of aberrations, CA etc stopped down a bit.
01-11-2016, 12:18 PM   #13
CarlJF's Avatar
In addition to what has been said, closing the aperture will be useful to not get over your max shutter speed (or x-sync speed if using a flash).
Obviously, with the small sensor formats you don't have the same latitude to work than with the larger formats.
01-11-2016, 12:44 PM   #14
Otis Memorial Pentaxian
clackers's Avatar
Even if you engineered the aperture to open only ever by the same amount, each time you change the focal length the F-stop changes, since it's a ratio. :-)
01-11-2016, 12:51 PM   #15
Digitiser of Film
BigMackCam's Avatar
Understood, but for instance with the Panny, it has a real aperture range of f/3.3-6.4. So, f/3.3 at it's widest point, which is 4.3mm. However, at that focal length you can stop down further if required - but since the f/3.3 at 4.3mm is equivalent to f/18 at 24mm on full frame, it doesn't seem like stopping down has much use. Same goes for the maximum apertures at all the other focal lengths too. That said, luftluss came up with the one situation where I think there might be justification in stopping down on this particular camera, and that's to get better depth of field on close focus shots...
aperture in small-sensor, benefit, blur, crop, diffraction, field, frame, lens, panny, photography, re, sharpness, shutter
How do variable aperture zooms report the aperture? IchabodCrane Pentax SLR Lens Discussion 11 06-26-2015 06:41 AM
Sensor Dust & Small Aperture Michael Piziak Pentax SLR Lens Discussion 4 02-13-2015 05:59 PM
What's the point of f/22? 6BQ5 Pentax SLR Lens Discussion 23 08-04-2013 10:28 PM
K5 Sensor Stains - what's the point freddyhard Pentax K-5 & K-5 II 22 06-09-2012 03:57 PM
aperture ring: what's the point? WMBP Pentax DSLR Discussion 33 02-23-2007 09:56 AM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
