If less size and weight was your primary motivation, then you simply chose the wrong lenses. I added a Panasonic GX7 as a lightweight option to supplement my Pentax gear a few months ago, and since then my K-30 has rarely left the house.
I have several lenses for my K-30, but my most common kit to go out with was the Sigma 30mm f1.4 and 85mm f1.4. And I love shooting really wide, so sometimes I would take along my Sigma 8-16mm, but I usually didn't want to add the weight and bulk of the additional lens.
Now, with my GX7, I substitute the Panasonic 20mm f1.7 for my Sigma 30, and the Olympus 75mm f1.8 for my Sigma 85. And for now, I have the Olympus 9mm fisheye handling the super wide angle. It's not as versatile as the Sigma 8-16mm, but it has approximately the same maximum angle of view. Here's how the comparative numbers work out:
K-30: 650g
8-16mm: 555g
30mm f1.4: 430g
85mm 1.4: 725g
Total:
2.36kg (5.2 lbs) GX7: 402g
9mm: 30g
20mm 1.7: 100g
75mm 1.8: 305g
Total:
837g (1.85 lbs)
So 5.2 lbs vs 1.85 lbs...a pretty drastic difference, as the K-30 kit weighs almost 3x as much. Not to mention that my m43 lenses are WAY smaller, which is really a bigger factor for me than the weight. I'm just loving being able to take a body and 3 lenses in a small, lightweight bag.
My original plan was to get the Olympus 45mm 1.8 for portrait duties, but somebody had the Olympus 75mm 1.8 locally on Craigslist for a price I couldn't resist. But it's a bit long at times, so I'll probably replace it with the 45mm 1.8, which is smaller and also weighs much less (116g vs 305g for the 75mm). In which case my entire kit will be only 648g (1.42 lbs).
Just for fun, here are some pictures comparing my Olympus 9mm fisheye to the Sigma 8-16mm:
