Originally posted by Sandy Hancock Mike Oria (MikeSF on the forum) is right up there too.
There are plenty on this forum but to give the requester examples of Mikes works
Mike Oria Photography
Another I draw insperation from on Flickr
https://www.flickr.com/photos/inter211/ Originally posted by trigger.happy Btw, here are some of the photos I'm trying to improve on right now so LPs with similar subjects would be good study. I'm still using the kit lens so there might be some limitations but I'm looking to improving my technique first before moving on to better glass.
Ok, for a little critique, look at your two examples and ask yourself; Do they lead the eye? Do they look flat or are they taken to give the appearance of having depth/3d like? Is the main subject clearly defined and stand out? Regardless of colorization, if you look at any good landscape they all contain these key elements that helps make them interesting. This isn't just restricted to landscape. As a suggestion, take time to look at what it is you want to photograph. If you find something that catches your eye, look at it from different vantage points , then capture it from different angles so you can decide which You like best.
Many great landscapes are planned months/years in advance and the landscape photographer knows how the light is going be on a subject at a given year, month, day and time by using an ephemeris and will travel to a location to capture them at that time. You can use one for daily shoots to know at what time the lighting is best suited for where you plan to shoot. That's not to say you need to use one but these tools available help.
