Originally posted by FarmerJim If the aperture is 1.4 on a 50mm lens, the lens has a 37.5mm aperture diameter.
The lens diameter is not the aperture diameter, nor is such always the size of the iris opening,
per se. The f-number is the
ratio of focal length:entrance pupil diameter when focused at infinity and that diameter may or may not correspond to the size of the physical iris opening and is not bound directly by element size.
Originally posted by FarmerJim Wouldn't a larger lens, like the Sigma in my example, let more light in just because of the increased surface area of the lens?
Good question. The simple answer is that flux within the frame is the same. Going further, two lenses with the same image circle and relative aperture (f-number) will have the same amount of light to the image plane regardless of front element diameter or focal length or format! No light lost, no light thrown away.
Going back to the simple case of same format, same focal length, same aperture, different size front element. The answer becomes clear when you trace the rays at frame edge and realize that the "view" from the image plane is the same. You can't take in more light than what is coming from the subject...or at least it is not a good thing to do so. When we do, it is called "flare".
