Originally posted by Outis I'm going to be camping in the Nevada desert in June. What do you recommend for keeping electronics (camera, laptop, etc.) cool in a hot car? I was thinking of sticking them in a cooler with no ice or anything, but I'm not sure if this would be enough or whether you guys have better ideas.
Everything said so far about oil getting on the blades is correct. It can get on the blades, vaporize into haze on your lens, and also ruin your camera for grease inside the camera. If you have an electronic camera, the electronics can be damaged.
Be sure to check your campgrounds' safety out. Some of the Nevada campgrounds can be unsafe at times. One of my photography professor friends related a story where her friend twice, separated by more than a decade, camped at Death Valley with a large photography group and both times the groups were robbed at gunpoint overnight. That said, I like to think that's an exception and not a rule.
If you haven't planned out your full itinerary, I'd recommend some time at Rhyolite. Here are some of my shots from there:
Nevada has some amazing ghost towns that the desert has well preserved.
Also, most any grocer in Nevada will sell dry ice. So if you find a cooler isn't keeping your gear cool enough, putting your gear at the bottom, loading the cooler with clothes, and putting a couple card-deck-sized pieces of dry ice at the top will add a few hours or so to how long your gear will stay cool. Of course, if your gear is resting on top of the dry ice that's going to freeze your gear's lubricating oils and cause it to break down into a thick, gummy mess.
If you have a moon roof, leave it cracked. If not, crack the windows. That will also help prevent your windows from blowing out if the inside of your car gets too hot.
One other general safety tip, if you're planning to drive state route 95 and never have before, that road is what nightmare horror movies are made of. It is TERRIFYING to drive. The road is long and straight and cars just look like they're miles away for 15, 20 minutes and then in a matter of seconds they pass you at 80-100 MPH. And it's two lanes with just a dashed line between them. The closest I've come to dying in my car was on our honeymoon driving 95 from Vegas to Rhyolite. We were doing about 70 and this chick decided to pass a TEN-TRUCK convoy. She was easily going over 100 and darted back into her lane with less than two feet between us. I flashed my high beams, honked, slammed on my brakes and she had no compunction about driving head on into someone. That stretch of road has daily fatal accidents. And when she finally got past that convoy, I was going less than 30, thanks to slamming on my brakes, and we were very nearly rear-ended by the truck behind us that didn't feel as much urgency to avoid an accident.
Originally posted by Edgar_in_Indy Wouldn't the trunk be cooler? Also, less chance of theft there.
I leave my moon roof cracked and that helps a LOT with the heat. The trunk gets just as hot as inside my car but stays hotter longer (well into the night) because it doesn't get to cool down with AC or open windows.
