08-28-2016, 02:18 AM   #16
pjv
Otis Memorial Pentaxian
pjv's Avatar
QuoteOriginally posted by kjphilippona Quote
Not sure what a good one will cost, maybe $200.
I found this Kim and hope it helps.
Best Professional Tripods Under $200 (Head-to-Head Review)
08-28-2016, 02:20 AM   #17
Jacquot's Avatar
I'm not sure where you are, but Manfrotto has a rebate in place through the end of September. I purchased a tripod at Adorama a few weeks ago and really love it, extremely solid and sturdy, a bit heavy, but I am using it for indoor work, so that is OK with me. I got what amounted to a 20% discount. Worlds better than what it replaced...
08-28-2016, 02:41 AM   #18
PEG Moderator
Kerrowdown's Avatar
Just a thought... buy a bigger/heavier tripod than you currently need, from one of the reputable brands.
This will probably then last you a lifetime, without any further tripod upgrades required in the future... also saving you money to spend on lenses.
08-28-2016, 06:08 AM   #19
kjphilippona's Avatar
Thanks everyone, I will do some shopping
09-06-2016, 02:08 PM   #20
Maybe too late, but let me suggest these less usual, but pretty solid wooden tripods:
Berlebach
09-06-2016, 02:53 PM   #21
UncleVanya's Avatar
QuoteOriginally posted by Clou Quote
Berlebach
Those seem over the top for a 'non-pro' which is what the OP said at the start. I think the budget is likely much much below that.
09-06-2016, 03:03 PM   #22
MarkJerling's Avatar
I now own a Sunpak Ultra 7000TM and it has worked fine when used with my K-01, K30 and K50 with small zooms or prime lenses. I attached my K3 with battery grip and Tamron 70-200 to fine adjust the auto focus and it was not very sturdy. I would not want to attempt using it out in the field. I am just a hobby photographer and don't need a professional tripod, just a better made sturdy one that will secure my camera and lens. Any suggestion's?
If you're cheap like me, and want an industrial sturdy tripod, use a surveyors tripod with a camera ball-mount and screw adapter.
09-06-2016, 09:29 PM   #23
emalvick's Avatar
It's worth putting yourself into a budget where you can buy the legs and heads separately. It makes things interchangeable, especially if you find yourself hating one head type or needing taller or more compact legs...
I'm a tall guy, so it took a few iterations to find the right legs. And I eventually bought a pro level ball head because I found it a good investment.
Finally... Consider a system with a weight capacity about twice what your heaviest camera config will be. Note that the lowest capacity of your legs and heads governs. Like another said, weight doesn't matter much, but it is a proxy for rigidity.
And it can be important for the head, which can come under a lot of torque. You don't want creep while taking a long exposure.
09-07-2016, 06:20 AM   #24
I am not tall only 6'1", but most tripods i have looked at have a max height of only 68". I don't want to be hunched over all the time taking pictures
09-07-2016, 11:50 AM - 1 Like   #25
Sometimes the Special Offer category has some nice things at a lower price.
09-07-2016, 12:42 PM - 1 Like   #26
Those are really nice, maybe i can get one of my cousins to pick me up one
09-07-2016, 01:30 PM - 1 Like   #27
amateur dirt farmer
pepperberry farm's Avatar
and the not-short guy at 5'6" chuckles....
09-07-2016, 02:04 PM   #28
PEG Moderator
Kerrowdown's Avatar
Check this one out then... It extends up to 2.56m (101")
Benbo Clasic No 2 reviews - Pentax Camera Accessory Review Database
09-07-2016, 02:34 PM   #29
bwDraco's Avatar
Bear in mind that the head (if a separate part) and camera body add several inches. That should add enough height to avoid the need to lean forward excessively.
Draco
09-07-2016, 03:17 PM - 1 Like   #30
As I said before - surveyor's tripod.
photography, tiltall, tripod
Looking for a sturdy, lightweight travel tripod bobbotron Pentax Camera and Field Accessories 50 07-04-2016 04:49 AM
What cheap old (too ugly to call vintage) tripod's great if all ya want is STURDY? goatsNdonkey Pentax Camera and Field Accessories 11 04-05-2016 08:02 AM
For Sale - Sold: Tiltall Tripod - Sturdy (Worldwide) Classic_Obsession Sold Items 8 07-09-2010 07:21 PM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
