Originally posted by Digitalis Will it be visible on an 8X10 print? possibly. Scoff if you must, but if both images are un-sharpened there will be a visible difference even at 8X10 print size.
At f/32, I don't think anyone would disagree with this, that calculator sure doesn't.
I can't speak to 35mm, but I do know aps-c and 8x10 prints pretty well, and what I've found is in agreement with the calculator, which puts f/16 just on the cusp of 'diffraction limited' for this sensor and print size. Out of my dfa100mm macro, I do notice a drop in sharpness from f/16 to f/22 at 8x10, and I'd only use f/22 if I have a good reason. F/11 to f/16 also has a drop if I went looking for it, but not so much that I spent time worrying about it.
This was especially true when I was using a 6mp sensor. It just couldn't capture enough detail that the loss in lens resolution from f/11 to f/16 wasn't as big a deal as the loss of DoF from f/16 to f/11 was. This also seems to agree with the calculator when you use pixel pitch instead of print size as your criteria.
Since moving to a k5iis, I've found my same guidelines work fine for 8x10 prints, but when it comes to larger stuff (or more commonly pixel peeping), I've knocked my guidelines back about a stop and a half for general use. That said, f/5.6 to f/8 and focus stacking is a beautiful thing when it's applicable.
