Originally posted by bobmaxja I have none of these problems with my K-5 , it was made on a Monday
You should seek out the threads on this forum from when the K5 came out.
Knowledge is a wonderful thing, arm yourself with some.
---------- Post added 01-29-17 at 01:53 PM ----------
Originally posted by Rondec I think the point is that X Trans is not any better or worse than the Bayer array, just different. The biggest problem is its lack of support and the weird advertising Fuji has used over time to say that their crop cameras are better than their competitors full frame cameras. The question is if X Trans solves any problems (maybe a little bit of moire but that's not a big deal any more), makes life more difficult (X Trans support isn't as wide spread as Bayer), and how much Fuji massages their files beneath their surface to make them look cleaner than competitors.
I don't really like the interface, but otherwise they have nice glass and perform similarly to other APS-C cameras of similar generation.
Sensors seem to have reached a point where moire is less of an issue, which is why we are now seeing cameras that no longer have the low pass filter. Fuji was able to do away with the low pass filter a couple of generations prior with the X-Trans sensor. Lack of support is less of an issue, X-Trans is supported quite well by numerous software manufacturers, though it did take Adobe a while to get it right.
Fuji in camera processing is definitely an issue, but one that is easily solved either by shooting RAW, or by going into the settings and changing them.
The X-T1/ XT-2 are as close as I've seen to the ergonomics of the Pentax LX, a camera I was particularly fond of, and the bodies are much more compact than the rather cumbersome bricks that every other manufacturer seems intent on foisting on us, Pentax included.
The downsides of the Fuji system are battery capacity, they are a small, rather power hungry camera, capable of holding a rather small battery. You aren't going to get a thousand or more shots on a Fuji, more like a couple of hundred is what should be expected, the glass is quite expensive. OTOH, it is extremely good glass, and I never quite got comfortable with the EVF. It gave me eyestrain. Apparently my situation was not common.
