Originally posted by alamo5000 I am going to be using Lightroom and RAW files on a windows based system. Keeping in mind that I am not a professional nor do I do gaming I want something 'good enough' that will still fit my other requirements of size and not requiring me to sell a kidney to get it. Knowing those bits of information what would be my best bet for graphics cards considering those other things?
The question is, what you mean by 'good enough', and what you consider selling a kidney.
Smaller laptops either use lower-performance components or they use higher-cost components. Low Cost, Performance, Small Size: pick two!
I know that figuring this out is not simple. If you must rely on a salesperson for help, your best bet might be to talk with someone who works for a photography store that also sells computers, such as B&H Photo and Video. The scary part of this if you are not able to cross-check the salesperson's suggestions is the sense that you have to trust someone who earns more money by upselling you, it's rather like buying a car without understanding the technology or the marketplace - a visit to the financial surgeon whose services can involve a radical cashectomy.
Some specifics:
If I were you, I would use a 512 GB SSD as the main drive and as storage for the images being developed, archive finished work on a separate drive - a really small machine won't hold the second drive, or it will hold a hard drive of limited capacity. SSDs have no moving parts and are a better suit the inside of a laptop than a hard drive with its spinning platters.
Don't even think of a computer with less than 8 GB of main RAM; consider 16 GB.
Take a look at
Adobe's advice on graphics processors for Lightroom.
You may want to consider the sort of research that I am just beginning: color management. If you are using the laptop's screen for editing, you will do best with a screen that can accurately represent all the colors that your camera can generate. For that, you would need a wide-gamut display built around an "IPS" LCD panel, which you can calibrate using a purpose-built tool. Dell brands these as PremierColor. They are not inexpensive, and you may find that Dell wants to sell you a Precision Mobile Workstation to get one. Precision Mobile Workstations are Not Cheap. I have not implemented color management yet on an external monitor, and I read of problems with the color management software that Dell uses, so I would also buy one far enough in advance of the move to Shanghai that you can test the assembled computer and Lightroom and correct problems.
Reason: Adding advice to discuss with a photography-oriented computer dealer.
