03-23-2017, 08:56 AM   #1
Aerlind's Avatar
Tips on shooting in humidity and rain?
Wise friends!
I'll be going to Kentucky in April to watch (and photograph because why not?) the Rolex Kentucky 3-day Event (equine event). I've been twice before and both times, the cross-country day (where you can literally photograph up-close and personally with the competitors) has been wet, rainy, and humid. I did alright my first year because I was under the wing (and using the equipment of) two professional photographers, but last time I went my poor lens and camera got hopelessly wet and fogged. I live in Colorado, so rain and humidity aren't things I deal with....even if your lens does get wet, if you take it inside for 5 minutes it's dry again.
I've upgraded since then to the K-3, so hopefully the camera itself is safe from the rain, but what do I do with my lenses? I don't have the funds for weather-sealed lenses. The "poor man's solution" I came up with was cutting a hole in a plastic bag and taping it around the lens hood, with the rest of the bag covering the lens/camera. Are there better (and not bank-breaking) solutions out there? The plastic bag trick only works with my one lens because it has a straight hood, my other lens that I'll use has a flower-petal hood.
I figure if I go prepared this year, it won't rain at all!
03-23-2017, 09:22 AM   #2
jlstrawman's Avatar
No experience with this; just looked interesting. Not cheap.
Learn How to Protect your DSLR with our Camera Cover
03-23-2017, 10:22 AM   #3
Just search Amazon for DSLR rain cover. There are multiple solutions ranging in price, some are fairly cheap. Read the comments, see which ones have good ratings. Imo most of them should be able to protect the camera from light to moderate rain.
03-23-2017, 10:52 AM   #4
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I bought these:
OP/TECH USA 18" Rainsleeve (Set of 2) 9001132 B&H Photo
They work well for me shooting in the rain. And they come in two different sizes, 18 inch and 8 inch. I bought the 18" because it covers my long lenses and my flash.
03-23-2017, 11:30 AM   #5
Humidity shouldn't be a problem, otherwise there wouldn't be a working DSLR on the east coast. What lenes are you bringing that aren't weather sealed?
Have you considered renting a WR lens for the weekend? I've used LensRentals.com and was very pleased at both the price and the service when I rented a DA*60-250 from them for a trip in to Denali National Park.
03-23-2017, 11:45 AM   #6
Resident Bagpiper
bertwert's Avatar
The camera is only WR if the lenses are WR.
Take a look here, maybe:
Rain Protection | B&H Photo Video
03-23-2017, 12:10 PM   #7
cali92rs's Avatar
Stay inside, shoot photos inside the bar
03-23-2017, 01:07 PM   #8
The plastic bag trick is great and dirt cheap. If you want to advance, still on budget, put a small textile bag with rice inside the camera plastic bag too. It will absorb the moist in the air and prevents condensation inside the plastic bag/lens/camera.
03-23-2017, 08:04 PM   #9
dms
If the lens is not zoom, or if it is and you don't zoom, I should think the plastic bag will be fine--so long as it is not a very heavy rain. But anyway carry a second lens protected, so you can change if need be. Also make sure the lens to camera area is not open/no gap (no takumar screw mount). A zone focused lens with said plastic bag covering much of the camera as well would be good.
03-24-2017, 04:18 AM   #10
For the humidity, keep your gear in the trunk of your car. If it inside of the car with you and you are running the A/C, the lens will fog up when it is exposed to the humidity due to the warmer air temp.
Tim
03-24-2017, 01:29 PM   #11
Aerlind's Avatar
QuoteOriginally posted by skierd Quote
I'll have an ooooooold FA 28-200mm lens, and a newer DA 55-300mm lens. Both Pentax lenses. It was the 28-200 that fogged up badly last time, if I remember correctly.
I hadn't thought about a lens rental! I'll definitely look into that, having even a little more zoom would be worth it for the weekend. Thanks!
03-25-2017, 01:39 AM   #12
The best I can think of.
umbrella hat | eBay
bag, camera, event, hood, kentucky, lens, lenses, photograph, photography, plastic, rain
Nature I'm shooting in the rain, just shooting in the rain dewolf Post Your Photos! 8 01-30-2017 09:56 PM
Rain/snow/humidity + Sigma 17-50 and other non-sealed lenses with motor bobik314 Pentax SLR Lens Discussion 6 11-13-2016 11:47 AM
Shooting In High Humidity Racer X 69 Photographic Technique 16 12-05-2012 02:28 PM
Shooting in Gym Humidity KidLogic Photographic Technique 7 01-13-2011 11:18 AM
High Humidity shooting? k20d over k-x p0opstlnksal0t Troubleshooting and Beginner Help 11 11-02-2009 05:38 AM
All times are GMT -7. The time now is 11:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
