04-01-2017, 06:59 PM   #1
Strange artifacts in photo - What could cause this?
I am wondering if anyone has any thoughts on what would cause the strange artifacts in the photo below. I shot this using a K-1 and 100mm WR macro. I noticed this recently when I was deleting photos i didn't want. You can see multi-coloured dots on the in focus red berries and there are white dots with halos in the out of focus red berries. I took about 6 photos of the same shot and they were all the same. This is the only time I have seen these in my photos and haven't seen them in photos taken after this. The camera was sitting right at ground level and it was under full sun. Any feedback would be appreciated. Thanks
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
04-01-2017, 07:06 PM   #2
amoringello's Avatar
Its called bokeh. The reflections / specular-highlights off the berries appears to be multicolored in many areas.
When out of focus the result can be multicolored-out-of-focus spots.
04-01-2017, 07:49 PM   #3
clem's Avatar
A guess
It could be the sun's angle (or if a flash was used) was reflecting in incoming light off the internal lens elements
04-01-2017, 09:36 PM   #4
Otis Memorial Pentaxian
I believe you are seeing reflections of the light source and objects in the room. Had the berries been misted?
Edit: I just noticed what the sprig is set on. Those are prismatic reflections off the ground glass below.
04-02-2017, 07:26 AM   #5
First thing I noticed was this area in the crop below... (didn't get a chance to get to my desktop until now to post what I was talking about).
Either surface is oily or some sort of metamerism is reflecting multiple colors off the berries.
It isn't terribly uncommon on all sorts of things. Nylon yarn/thread can also cause some prismatic highlights, as can pet hair sometimes.
04-02-2017, 01:17 PM   #6
lightbox's Avatar
The patterns in the second photo look like airy disc diffraction patterns. Maybe coincidence, but it's very eerily similar.
Could this be aperture related?
04-02-2017, 07:20 PM   #7
Thanks everyone for your comments. I took this photo when I was out for a walk and saw the sprig as a possibly interesting contrast to the snow. The sprig was actually just sitting on surface of the snow which had slightly melted then refroze creating ice crystals on the surface. The sun was really bright at the time. It almost does look like the sprig is sitting on glass. Its possible the berries could have had some moisture/frost or natural oils on them but i never really looked that closely at the time. I have now used an air blower to lightly remove dust from the mirror box area of the camera and my lens. I will also have a close look at my lens to see if there is any contaminants on the lens glass. I had not noticed anything previously.
If this is aperture related is there any way to test this.
Thanks again your replies are appreciated.
04-02-2017, 07:57 PM   #8
lightbox's Avatar
QuoteOriginally posted by silvercamp Quote
There's probably nothing wrong with the lens- I was just pointing out a phenomenon of point sources of light and small apertures.
Hopefully an optics expert chimes in here, but what I was thinking was that the specular highlights on your berries are so small that they are essentially point sources of light. At high aperture values, after diffraction kicks in, those point sources could manifest as airy discs when you defocus (as is the case in photo #2).
Some more info here: Circular Aperture Diffraction
Every lens will do this-- I'm thinking that you just found a subject with very interesting highlights (as others have mentioned) which cause the effect to show. You can test this by slowly opening up the aperture and seeing if the effect gets fainter or disappears. Your images are f/13. Try f/11, then f/9.5, f/8, etc. If it is aperture related diffraction then it should disappear rather quickly.
artifacts, artifacts in photo, berries, cause, dots, focus, photo, photography, photos, shot
People ww2 artifacts dcmsox2004 Post Your Photos! 2 08-19-2015 03:30 PM
Serious battery drain! What could cause this? Dewman Troubleshooting and Beginner Help 29 07-18-2014 06:08 PM
Could an atheist possibly cause change in the RCC? Peter Zack General Talk 31 04-20-2010 08:52 AM
purple haze? what could be the cause JimD_K10D Troubleshooting and Beginner Help 18 10-10-2009 06:54 AM
could the K10 new firmware cause this? slip Pentax DSLR Discussion 3 01-24-2007 06:37 PM
All times are GMT -7. The time now is 04:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
