Originally posted by bigdavephoto ...The main object of his post was that he had to move the saturation slider a good ways just to make the flowers look light pink again but at the same time, he over saturated the rest of the photo...
If the saturation slider brings the pink back then it's not a case of irrecoverable overexposure. Colors related to red, such as pink, are a frequent trigger for extra software processing. Sensors are sensitive to invisible IR light, so there's usually an IR Cut filter in front of the sensor. The exact cutoff point of the filter can skew the way some reds look.
A little bit of work with processing software should be able to fix that. Using Lightroom as an example, I would first try to reduce the highlight slider. If that doesn't fix it, the HSL (hue, saturation, luminance) panel would be my next stop. Increase only red/magenta saturation, or decrease their luminance.
