Originally posted by Ian Stuart Forsyth There is resolution as in pixel count and then there is resolution in what the lens and the camera can resolve together.
As you crop the image circle that is projected by the lens the more that image has to be enlarged, this equals less resolution is capture . If there was no penalty to cropping with a higher pixel density camera we all would be shooting with a 100mm lens on the K3 cropped to 6mp image and expect that to give us the same captured resolution as the DS with its 6mp sensor when used with a 200mm lens.
but we both know this is not possible.
Enlargement is simply not an issue on digital because it is the display that determines the image size. To your monitor, a pixel from a small sensor in exactly the same as the pixel from a large sensor. Which is why a Panasonic one inch sensor at 100 ISO can produce practically the same image (same number of LW/PH) as a D7500. Sensor size has nothing to do with it.
Quote: As you crop the image circle that is projected by the lens the more that image has to be enlarged, this equals less resolution is capture .
Definitely not, only the poorest lenses are equalled in potential resolution by modern sensors. There's lot's of room for for smaller pixel sensors to increase resolution from the same lens. My K-3 with an FA 1.7 AF Adapter on it still picks up quite a lot of resolution using my DA*200 or Tammy 300 2.8. Even my Q continues to show serious resolution gains on a small subject used on DA* quality lens with the adapter.
There is not a shred of evidence to support the notion that modern lenses can't resolve at least 1.7 time as much as a modern sensor and I can show you tests with a 1.7 TC to confirm that.
A shot taken with my Q, and the Tamron 300 for an effective focal length of 1200mm. There is still enough resolution to resolve feather detail.
My guess is that 1/4 the size of an APs-c sensor.
This is taken 40 meters away from my porch. A lot of the detail that may have been lost is because I'm far away. There's a lot of atmosphere between me and there, yet i still have feather detail. Shot with the same lens and K-1 then enlarged the bird would be just a little spot on the image, possibly not even recognizable as a bird.
Closer is always better, but if you can't get closer, reducing your sensor size is a good start if your light is good enough to give you a decent shutter speed at 100 ISO.
