05-31-2017, 08:50 AM   #16
QuoteOriginally posted by fstopfanatic Quote
Thanks to you all for your insight. I assumed I was on the right track considering air quality. I'll try my polarizing filter and see if it helps. Waiting for a truly clear day here may not be an option.
When you try your polarizing filter, keep in mind that the strongest polarization of the scattered light is at a right angle to the light source (probably the sun). You can actually see this on a non-cloudy day when the sun is up: while looking at the sky at a right angle (90 degrees) with respect to the sun, rotate the polarizer. You will see a strong effect (the sky gets darker = you've filtered out some of the scattered light), whereas if you repeat the experiment looking more or less towards the sun (or far away from the sun), the effect will be less (there's not as much scattered, polarized light for the filter to reject).
Also keep in mind when shooting on a hazy day, that the crud (water, dust, pollen, ...) does what is called "forward scattering." This is the scientist's term for the fact that small particles tend to forward the light along the direction from which it came - a bit of a beaming effect. So, if you are looking through the air at something sort of in the direction of the sun, the scattered light will be worse than if you are looking at something with the sun behind you.
It's all just physics!!
air, air quality effects, atmosphere, effects on landscape, haze, horizon, iq, landscape, landscape photo, landscapes, miles, moon, ohio, photography, photos, quality, shots, tool
K3 IQ vs KS2 IQ Senko Pentax K-3 18 03-11-2016 07:52 AM
Quality Photo Effects Software? Richard Briggs Digital Processing, Software, and Printing 0 08-16-2013 01:55 AM
Tamron 70-200 IQ vs 135 prime IQ TOUGEFC Pentax SLR Lens Discussion 21 08-25-2011 05:48 AM
Argentinian Air Force Air Show Andres Post Your Photos! 5 05-08-2009 06:44 PM
Canon 450D IQ is not a match for Pentax K10D IQ. Voe Pentax SLR Lens Discussion 19 07-11-2008 09:15 AM
All times are GMT -7. The time now is 06:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
