11-05-2017, 11:00 AM   #1
Can an owner of the orig m42 single round shafted "Asahi Bellows Unit" answer a "?"
If you have a copy of the original m42 screw mount "Asahi Bellows Unit" or "Asahi Bellows Unit S," which has a single round focusing shaft underneath it, labeled on either side with numbered scales on each side of the shaft indicating magnification levels and/or exposure increase amounts -- can you do me a favor? Can you retract the bellows to its minimum extension and measure the flange-to-flange distance of that minimum extension in millimeters?
(Yes, I checked the reviews section, and the answer is not there.)
11-05-2017, 01:13 PM   #2
swanlefitte's Avatar
Try this pdf. Minimum magnification is .62 and on the bellows 2 minimum distance is 37mm.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://extreme-macro.co...SqCs9GTiKB40J_
---------- Post added 11-05-17 at 01:40 PM ----------
Using this calculator, .62 magnification on the standard takumar 55mm with max magnification of .13x gives me 27mm. However the 55 f2 has a different magnification, not sure which 55 they mean.
Pentax-M bellows and what makes great bellows for macro stacking photography
11-05-2017, 04:30 PM   #3
QuoteOriginally posted by swanlefitte Quote
Using tables for a later m42 bellows to determine the rationship between extension and magnification for the 55mm f1.8 Takumar, I computed what extension should be for the lower minimum magnification of the "Asahi Pentax Bellows Unit I" at it's minimum extension, which is less than the model the table is for. I get a minimum extension of 35.23mm for the Asahi Pentax Bellows Unit I. I'm not sure if that is the same as the Asahi Bellows Unit S, the one I am curious about, but it does look similar (but not exactly the same as) it.
Thanks for the link.
I'm glad I can still remember some algebra!
answer, extension, m42, m42 single round, magnification, orig m42, photography, round, shaft
Different Versions of Asahi Bellows Unit II (M42)? electrofunk Pentax Camera and Field Accessories 5 02-09-2014 03:27 PM
keep getting shafted on the M Wired Pentax SLR Lens Discussion 50 02-11-2011 05:41 PM
Round and round and round brkl Post Your Photos! 6 04-20-2009 11:19 AM
All times are GMT -7. The time now is 02:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
