11-26-2017, 04:29 AM   #1
Tripod plate, help!!
Hi there
Travelled to the other side of the world to Auckland and was ready to set up my gear when I realised that for some bizarre reason I'd forgotten the plate to attach my Velbon tripod. This is a major disaster as I want to do some night shots, longer exposures. Any idea whether I can buy such a plate? Are there generic ones? The head is a PHD-42Q. Any help much, much appreciated
11-26-2017, 04:38 AM - 1 Like   #2
Alex645's Avatar
The Velbon QB-62 is the quick release plate or shoe that you'll need. There are many camera stores in Auckland and I believe most are open on Sundays. I'd suggest calling around. Velbons are decent beginner tripods, but if no one has just the plate, maybe it's a sign that one of the souvenirs you'll bring home from NZ is a new and better tripod.
11-26-2017, 05:00 AM - 1 Like   #3
WPRESTO's Avatar
I believe that Velbon used the universal 42mm square dovetail plate that was a superior design to the Arca-Swiss so-called quick release system*. 42mm square plates were once available from multiple manufacturers including Bilora, Kaiser, Cullmann, Sunpak, Vanguard and others. If you find a small square plate under any of these brands, its worth a try. The plate is likely to have a video pin in front of the 1/4 X 20 screw (the video pin is always spring mounted). However, neither Slik nor Manfrotto/Bogen ever used a 42mm square dovetail so don't bother with those even if they look as if they'd fit..
*The non-patented system that uses 42mm square dovetail plates is really QUICK for mounting/removing, but the manufacturers were never inventive in developing anti-twist plates, and that killed the system relative to the much slower, clumsier Arca-Swiss system.
11-26-2017, 08:17 AM - 1 Like   #4
UncleVanya's Avatar
Is the head removable? If so it may be easier to grab a head and a matching plate.
photography, plate, tripod
To "L plate" or "not L plate" (or other accessories) mhoule418 Troubleshooting and Beginner Help 7 11-26-2017 02:05 PM
Video Panning Tripod Head + L Plate Question. BruceBanner Pentax Camera and Field Accessories 3 11-21-2017 08:57 PM
For Sale - Sold: Induro PU-120 Arca Swiss type tripod plate Brand New! REDUCED! gsrokmix Sold Items 4 09-09-2017 07:47 AM
K3 II L arca plate and 60-250 tripod foot question: bbodine9 Pentax Camera and Field Accessories 4 04-23-2016 05:13 PM
How to adapt proprietary tripod head quick release plate to a common standard? Des Pentax Camera and Field Accessories 8 04-04-2016 04:52 PM
All times are GMT -7. The time now is 08:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
