Originally posted by KiloHotelphoto I really like the Joby ultrafit sling strap. I have two of them now and after practicing for about thirty minutes and making small adjustments I got it just how I like it. I sometimes like to carry a smaller lens like a 70-200 2.8 when I'm out with my long lens incase I stumble accross wildlife thats just to close and really like how this strap can keep it close to my body and easy to move into shooting position.
Joby UltraFit Sling Strap For Men (Charcoal, M to XL) JB01257 I've seen that sorta thing before but (correct me if I'm wrong), you can't use a Arcaswiss or other connecting base plate with it?
Anyhow, I think I have DIY'd a sorta solution that first impression seems to be working for me (hard to really tell till you have an actual field test).
What I did was take an old generic $15 L Plate I had lying around that wasn't being used, and I used the Allen key to take off the side of the L Plate leaving just the bottom plate. Then I took a hacksaw and sawed off a sizeable part of the base plate of the L plate, too shorten it. I then filed it down around the edges to minimise hard sharp edges then gave it two coats of permanent black marker over the silver cut edges
When I attach and rotate the base plate as to how the pictures below show I can get my neck straps to anchor down here instead of up at the D Rings. Giving it a whirl and holding the camera out in front of me in either portrait or landscape in LV mode and the straps do indeed no longer obscure my vision towards the screen, success! An Added bonus I can still quickly slip the camera onto the tripod, it's a bit weird doing it from the side, I really need a lever and not a twisty knob, something to invest in the future.
My only gripe is lens swapping is a bit weird now as I am used to the camera nestling on my stomach with the lens mount pointing straight out ahead (like the same direction as how you would shoot a pic, which is actually a bad habit to get into as stuff can blow right inside the camera!), currently now the opening is towards the floor, prolly better but I'm just not used to swapping at that orientation so I'm a bit slow.
Anyway, problem fixed I think. I really need a neck strap as I shoot with two cameras, I like to reach for the other one quickly thus allowing the other camera to hang around the neck in the meantime, a wrist/hand strap solution to this issue wouldn't really help me.
