Originally posted by PDL No, you do not get it. Back in the day when I shot only JPEG as a matter of course I only worked on copies of the original JPEG's. SOP in that day and age, but even using lossless formats to work on will not give you back the data discarded in the original JPEG conversion. Eight bit format concerted to sixteen bit format does not result in more data.
Raw gets saved as jpeg before you print or before posting on the web. Nobody prints or posts raw files. Same loss of data.
Reason: Rude comments removed.
