Originally posted by WPRESTO I basically agree with you BUT, tests of MFT cameras placed on very heavy tripods showed IQ degradation caused by first shutter curtain induced vibration when the camera was using longish shutter speeds.I suspect a shutter curtain induces less vibration that a mirror slap, but I'm not sure whether the shutter curtain of an MFT is a greater source of vibration-inducing impact than a DSLR shutter or mirror, because DSLRs may have a better ratio of mass-of-shutter-curtain or mass-of-mirror to mass-of-camera-body. I don't think it's something one could or should calculate or guess. Determining whether physically bigger cameras have an advantage would require actual testing.
BTW, in theory the vibration problem should disappear at very long shutter speeds. As the shutter remains open longer, the vibrations die out and the duration of them comes to constitute only a small fraction of the entire exposure time, eventually becoming too small to notice. This effect was explained to me by a pro who sometimes took pictures by UV light in an otherwise totally darkened room with exposures that were 15 minutes up to more than an hour long. Aside from closing doors and people walking by, there was a heavy electric fork-lift (called "Uncle Louis") that sometimes drove down the hall shaking the entire floor of the building - impossible to ignore if you were sitting in one of the offices. But those vibrations were so brief relative to the length of the exposure, their effect could not be detected on the negatives or prints.
Vibrations only die out if there's nothing that keeps exciting the system either from the outside (e.g., "Uncle Louis") or from the inside (e.g., the SR system twitching the sensor a bit to keep it in place).
These SR-induced vibrations don't always die out. Electronic noise in the SR system sensors causes tiny twitches. Under most conditions, the twitches have no noticeable effect and do die out. But if the natural frequency of the tripod-head-camera-lens system matches the resonant frequency of the SR system control loop, that doesn't happen. In the worst case, the tiniest vibration of sensor noise amplifies and the vibrations get worse and worse over time.
As for calculating the effect, it's exactly what mechanical engineers and control system designers are paid to do. There's various ways to model the tripod-head-camera-lens system to estimate the dynamical behavior of it as a mechanical system (e.g., the natural frequencies of the system in various vibrational directions). And an electrical engineer can calculate the response of the SR system to various frequencies. Or these can be measured in various ways, too.
