Now hear me out... I would also like to point out that I am not standing by this statement per se, rather I am putting my own observations out there to see if anyone else feels similarity or disagrees wholly etc.
I recently underwent another afternoon of fine tuning my adjustments for various lenses following standard Focus Chart protocols, perhaps more importantly I was repeating how I was performing the tests like it did last time (some 6-12 months ago).
Before I began fiddling I noted down what my previous focus chart testing results were (Looked at 'Apply One' with each AF lens etc). This time round all my testing gave different results, quite massively so in fact. Some lenses were +3 for the old Apply One, but now this recent test told me -7 was better... which just leaves me to believe how accurate can these tests really be if repeating them on a different day (trying to replicate the exact set up as possible) leads to pretty drastic FA (Fine Adjustment) changes. Can the camera change over time, or is it simply impossible to replicate the previous Focus Chart set up so that the FA settings come out very similar?
This was my first warning that Focus Charts were not doing the job for me. If I can't (get consistent results) with tripods and a controlled set up (on different days)... then what's in the field shooting really going to be like?
I also noted that there is a
massive difference in results depending upon whether I use a 2 sec timer vs not. It didn't matter if it was a FA 50mm@1.4 or a MF Samyang 85@1.4, just the very act of touching the shutter lightly and pressing it down shifted the focus point
slightly off centre (compared to using a timer) which then again made me question the validity of the Focus Chart process (because then the FA for each way varied tremendously).
I mean... fine, I have fine tuned my lenses to be accurate for when I have them tripodded up, shoot with timer and aim at fairly close range targets... like I do that kind of shooting a lot in the field...
not....
So what am I FA my lenses for? A scenario I rarely replicate in the field, or should I be FA my lenses for actual shooting conditions that involve me being still as I can, handholding, SR on, squeezing the shutter button gently and not in timer mode...
Shooting f1.4 with a 50 or 85 has a huge amount of deviation in where the focus is lies, tuning it for a tripod and timer scenario seems pointless to me, once you try those settings in the field in your hand, SR on.. I find the FA irrelevant.
Furthermore, this was the first time I tried FA for MF lenses (like the aforementioned Samyang 85/1.4). What I learned here (and was more obviously apparent) is that the AF confirmation is not a single quick point in a range, but actually a range itself. You can focus from near to far, green AF hex comes on, continue to focus (and the green hex confirmation is still showing as being in focus) until you continue to focus so much that it toggles off.... so what then... where do I fine tune my FA to be? If I focus from Far to Near it's a massive difference from Near to Far.
I tried to draw what I felt was happening (and this related to CIF, but the principle is perhaps the same?);
So when trying to FA for a MF lens... it seems nigh impossible, unless perhaps I try and FA for one end of the spectrum, either FA for when focusing from Near to Far, or Far to Near... but even when I tried doing either of those two things it was really hit or miss.
In the end I put an empty beer bottle on my mailing box and took pics with the FA and felt none of them really improved anything (not with the AF lenses or MF). With MF lenses I was just better to use my eye and then take the shot, 100% completely ignore the focus confirmation. Trusting it would result in more fuzzy shots than just using my eye, seeing when I felt the text on the bottle was at it's crispness and then shoot.
Additionally, I noted that sometimes Auto Focus confirmation wouldn't even 'come on' at all, panning away, depressing the shutter and trying again, nothing worked, actually turning the unit off and back on again seemed to 'kick it up the arse' to presenting the Auto Focus confirmation again... so it was quite erratic as to whether it wanted to be used or not :S
With AF lenses I had to change the FA, none of the settings I had used in a Focus Chart were relevant now that I am handholding it out in the field with SR etc.
So... this really begs the question... are Focus Charts then a complete waste of time? My conclusion is that I have a better shooting experience with trusting my eye with MF lenses and with AF lenses do the FA for in the field scenarios.
What's everyone's stance on this?
Cheers,
Bruce
