Originally posted by Thagomizer The eyes and imagination you bring to your subject are more important than the gear.
Like all old saws, this is true to a point, but if one works hard enough at any avocation, then he or she will reach a point where gear does become a limiting factor. At some point, a person will squeeze all the juice that can be had out of a particular kit, and will either stagnate or will find something else, something better, that allows the next steps to be taken.
Using the film example, there is only so much quality that a 35mm negative can give. Once one has taken everything they can from that format, it's either settle into a stagnation where growth ends, or it's move on to something that will allow growth.
In my example, 35mm was only able to carry me so far down the creative path that I was on. When I reached the end of where that format could take me, I was left with the choice of stagnating or allowing my creativity to bloom with a different and better kit more suited to where I was going.
The kit I started with became a millstone, and new gear became very important.
The problem with the old imagination trumps gear horse is that it often doesn't recognize that gear can become very important. Too many people fail to recognize the importance of good or even great gear and what it can bring to the table by getting stuck in a mindset that if their pictures aren't good enough, it's their fault, not their gear's fault. Failing to recognize that one has outgrown their gear is more hobbling than buying new and improved in the hopes it will automatically make one better.
Here's another example of gear being as important as vision. My other hobby, the one that replaced the darkroom, is carpentry. I make little jewelry boxes for fun and to occupy my hands. As I spent many years in the construction trades I own some pretty good quality power tools that are well suited to home construction and renovation.
My jobsite table saw in particular is very decent quality, and light enough to be tossed into the back of my truck.
As it is what I had, I decided to make a jig that would mount on it for making finger joints, which is the joint type I am favouring at the moment. At some point I will probably start doing hand cut dovetails, but for now I am using a more simple type of joint.
My very good jobsite saw turned out to be pretty useless for making good finger joints. It's too light and it vibrates. This causes the sockets to be very slightly different depths, making tight joints impossible to achieve.
All of a sudden my "kit" wasn't good enough, so I bought a 300 pound hybrid cabinet saw, and just like that, my finger joints got good.
I could have stuck with the tool that wasn't good enough and continued to beat myself up trying to make it do something it couldn't do, but I recognized that I was asking it to perform outside of it's performance envelope, and that new "kit" was called for.
Just like when I was shooting 35mm and came to the conclusion that my vision required a better camera, I recognized that my carpentry required a better saw.
Don't get too tied to the idea that it's all about vision. Absolutely vision is important, but this is a technical game, and in technical games, equipment is also important.
Recognizing when one has hit the wall regarding equipment capabilities is as important as the vision and imagination that one brings to the table of creativity.
