Originally posted by swanlefitte I don't understand this part."One arc-minute corresponds to 0.003 inch at a distance of 10 inches. The inverse of 0.003 = 344, but it takes at least two pixels to resolve something, so double this number and we get about 700 ppi ats the resolution of the eye at one arc-minute. "
To me it seems that what is said is I can distinguish between the 344 pixels. That is more than "at least two pixels".
There is actually enough evidence to dispel the myth of 300 ppi being the optimal and that we cannot see more. Probably came from the magazine printing industry. Depending on who you listen too (and your own testing under your particular circumstances with your printer !!) there is reason to believe that we (assumption 20/20 vision) can certainly perceive a difference for images printed at 300 ppi and 600 ppi or 360 - 720 ppi dependent on subject matter. Further some reaserch suggest that maybe 900 -1000 ppi may be about the limit. On images that I have printed above 600 ppi on my Canon printers and 720 ppi on my Epson I do not see any benefits - YMMV
---------- Post added 11-11-18 at 06:48 AM ----------
Originally posted by Dartmoor Dave The part I don't understand is why anyone would ever look at a photographic print from ten inches away.
It is no surprise to me and if you have attended galleries and exhibitions you may observe the phenomena; an image gets the interest of an observer and that observer moves closer to examine in more detail ROI's. If that observer happens to be a fellow photographer the viewing distance will be limited by either nose or belly
Quote: When there is a lot going on in a photo that viewers need to be able to make out in detail, that photo is usually printed big enough that the detail can be seen from a comfortable viewing distance.
Usually is not always and commercial clients may well specify prints no larger than 10"x8" where the difference in higher PPI may well be appreciated.
Quote: Would anyone ever really make a print in the belief that the ideal viewing distance for it is ten inches?
No but a professional may well take into account that within the viewing area for the size of print viewers will be tempted to take a closer look!
Quote: Apart from the sort of gear-obsessed photographer who only takes photos of brick walls and test charts?
The comment is far from the truth for some and obvious to anyone who has worked in the photographic industry supplying clients in the areas of Industrial, Commercial and advertising work.
None of this may be of importance to the individual just as any or all of these factors may mean zero to some:
Sensor quality and DR
Pixel shift - what a waste of space
Quality of lens- any old bit of glass may do
Diffraction irrelevant - always shoot at f/32 it makes sense for DoF
Add your own here
If any of the above are considered important then why do we still get some people throwing away IQ at the final print stage?
To be clear this has
zero to do with image aesthetics and everything to do with mainting QC during the image making process. Arguing/discussing aesthetics is on a hiding to nothing. I may or may not agree with you what makes a good image. I do not like or see artistic/aesthetic value in a pile of bricks in the Tate gallery or an unmade bed or half a cow in resin exhibited as 'art', but that is just my view and I respect the right of others to have a different view
