Originally posted by swanlefitte Wondering about infinity and registration distance. Is there a mathematical function of this? I assume that the 44.6 + xmm will determine max distance. I assume this is a function of registration distance + difference. It would be cool to see a graph. You could see what lenses for different systems would do mounted on different systems.
If you have a lens of focal length, f mm, that is correctly focused at infinity for it's normal registration distance and you then shift the lens by x mm away from the sensor, the max distance will be:
MaxD = f*(2+ x/f + f/x)
That can be rewritten as:
MaxD = f^2/x + 2*f + x
A 28 mm lens shifted from its normal registration distance by 1 mm will have a new maximum will be 841 mm (about 2.8 ft)
A 300 mm lens shifted from its normal registration distance by 1 mm, will have a new maximum will be 90,601 mm (about 297 ft)
As you can see, the relationship is very sensitive to focal length and the graph is a parabola.
