Originally posted by ThorSanchez Have you thought about scavenging the helicoid mechanicsm from a $5 eBay lens, and using that in your design? Or does that violate the spirit of the build-your-own ethos? That would probably be much smoother and allow for finer focusing adjustments than a 3D printed version.
I have, actually! It'd be more accurate than a 3D printed helicoid, but not as accurate as a lead-screw type design.
The problem is that I have to make a slit for the aperture plate - which complicates the design a bit. I'd either have to have the aperture far in front of the single element
| [///] (), or I would need to put it in front and extend the barrel backwards through the helicoid, which means Im printing a lot of material... which pushes the size of the entire structure up
It's certainly doable! In fact, it's preferable over a 3D printed helicoid... BUT the problem is that for this particular design, it pushes the size up, and adds complexity in different places.
It is certainly an idea for a future plan! For now, though, I think Im going to go with the leadscrew design - it's very simple, and although slow, very accurate (once set, it just won't move anywhere - it would be a true "set and forget" focus when set to infinite focus, and for close-in work, the size of the structure can be made pretty small, allowing for even macro shots (apparently, single-element lenses, when stopped down, rival multi-thousand pound/dollar macro lenses in center sharpness (but not in CA and distortion though - that's what you're paying for! That's also why lenses have tons of elements these days instead of "just one/two")
It's a fascinating subject actually - I would love to learn more. For now though, I think I'll draw up a CAD model for the leadscrew design. Barrel-in-a-barrel, leadscrew at the bottom, pull it out from the front along the dovetail, keeping everything straight - o-ring at the back damps wobble. I could really do some way of turning the screw from the side rather than the front: it'd keep the bottom of the lens clearer... maybe there's something to be said for using the rack-and-pinion movement from an old telescope after all - put the knob in and the rack in a little dovetail and move it forward and backwards. Small and very lightm but can be moved by pushing on it...
I'll draw up some sketches for each of the possibilities and do a quick cost/benefit estimate on them.
Note to self (list of ideas to sketch out)
- Helicoid from existing lens
- Rack and pinion
- 3d printed helicoid
- leadscrew
1 - needs investigating
2 - potentially very simple - check accuracy with the existing telescope and see what we could manage
3 - is probably more trouble than it's worth - check if it can be done simply and discard
4 - draw up detailed sketches for possibilities on reducing complexity and ease-of-use
